First oil change in my SuperDuty
This will be the first oil change I have done in my F250 since I got it in May so I went to Carquest and got 5 quarts of oil and an oil filter. My first question is about how many quarts does a 5.4 hold? And should I get a Motorcraft oil filter rather than a Carquest? The # on the Carquest filter is 85372. The truck is a 2000 F250 5.4.
Thanks guys.
Thanks guys.
Your motor won't seize today from using a Fram filter but I challenge you to find a cheaper/poorer quality filter anywhere. There are plenty of sites attesting to the poor quality of Fram filters. Here's one (an older report) that I found quickly: Oil Filters Revealed - MiniMopar Resources
The Fram filters that use the silicon antidrainback valve are much different internally than the standard PH2.
i use carquest filters on my grandmothers car, i believe (dont hold me to it since filters manufactors vary by car makes) the carquest are made by Wix. same filter you would get at napa in most cases.
as for a problem with them, never had one.
for my ford i'll stick with the motorcraft filter since it is the best for the price, 3.48 at your local walmart (if you have a walmart near you). But a carquest red or blue line filters will be just fine. just for a reference the carquests blue line filter ($6.xx) is close to the cheap motorcraft filter.
but have others have said, NEVER spin a fram on to your engine. i found the hard way when i would get a dry start every time till i ditched them.
boxcar_tommie22
Oil & Lubrication
04-12-2011 02:24 PM
dalfollo
1997-2006 Expedition & Navigator
03-16-2004 08:06 AM
