grease fittings
grease fittings
I have found only two grease fittings on my 1998 light duty f-250 4X4. Are there any more that I should be looking for? If so, where? Also, on the older Fords there were small hex plugs in the ball joints and tie rod ends that you can replace with grease fitting, but this truck has sealed ball joints and the tie rod ends have a steel button where the grease fitting would go. Do these steel buttons come out? I've tried turning them with a plier and the didn't budge. Any help would be appreciated
grease fittings
My 97 F150 had two grease fittings. At 40K miles, I had to replace the squeeky pittman arm. I tried to remove the steel plugs to install the fittings. No luck and I made a few calls and everyone said I would get grease fittings on the replacement parts.
I bought some fittings, a drill bit, and a tap to make my own threads. Now my truck has 11 fittings and turns so quiet and smooth.
grease fittings
Drill and tap the ball joints ?
That's what I love about this forum, so many good ideas on it.
This summer I'll drill and tap the ball joints on the driver's side of my truck, they are the only ball joints that haven't been replaced yet.
Thanks for the info !!!!!
LeRoy Wolff, original owner of
1984 Ford F150
300 six 3 speed with overdrive
optional dual rusted out fenders
truck's nick name "Old Red"
1984 Ford F150
cokewithvanilla
1999 to 2016 Super Duty
11-27-2015 08:52 PM
caedo
06-02-2014 11:59 PM
AMSContr
10-20-2008 12:12 AM
