Front Suspension Brand Suggestions
I NEED to replace my ball joints and tie rod ends. The current ball joints have a straight grease zerk out the top that you can't get to because the U-joint there is in the way so its impossible to grease the tops. When I put the new ones in I'm gonna try to put a 90* zerk in there so that I can actually grease em... But, what brands do y'all suggest? I know Moog stuff is really good, but I don't know if there is a beefed up tie rod end available or better ball joints, from different brands, etc. The Dynatrac ball joints look pretty appealing but they are ungodly expensive. Anyone have experience with them? Any feedback would be greatly appreciated as I try and figure out what is best for my truck up there.
My MOOG parts have been in place for 75,000 miles or so. On and off the ranch travel. I've replaced front end parts on every vehicle I've owned for close to 40 years. I've always used MOOG. The only vehicle I ever had problems with was a 85 Extra Heavy 3/4 ton Chevy P/U. It ate brakes and suspension parts and engines and transmissions and tires and gas and........
Ball joints I also considered the Dynatracs but there is little feedback to be had. Plus just too many Benjamins. Instead two days ago I installed (with plenty of help) half of the Dana/Spicer 2020314 kit. Got a late start and only got the driver side done. I figured go with parts made by guys who made the axle. Complete kit with all seals, o rings etc. No grease zerks to interfere. Non-serviceable just like oem, cuz they are oem. Had 'em on two days, love 'em!
For the tie rod at the pitman arm I tried the upmarket AC Delco part, only got a year out of it before it was toast. Two years on the MOOG link and still tight as a nuns' burro. If it gives out "too soon" I'll try the XRF, but I have seen others replace them, check this link.
fightlivefree
01-05-2016 10:33 PM
boss1982
09-29-2011 09:53 PM
bkr2
07-17-2008 12:31 PM
eigenvector
10-10-2006 02:35 AM
