f-150 door locks
f-150 door locks
2001 f-150 king Ranch 4x4
No mater where I go someone seems to want to break into my truck. I'm sure I'm not the only one here with this problem.
The first time someone stuck a screw drive in the key hole and broke it off and opened the door they were successful. After the first time I glued the keyhole back into the door so that it wouldn't look so bad. I took out the bar that connect the key to the actual lock. I did this on both sides. They haven't gotten in since, but they break the locks out of the door every time I put them back. I just hope my battery doesn't die.
Any way what I'm asking is can get a stronger lock or put the same handles that are on the back doors on the front? could I just cut a hole for the # pad on the drivers side.
What have y'all done, if anything?
mnkeeking
15
11-26-2014 11:28 AM
Mocha Joe
06-26-2013 08:28 PM
