Code - PO 732
Here's what the book says.
P0782, P0732, P0733
SSA, SSB or Internal Transmission Components 2-3 shift error.
Engine rpm drop not detected when 2-3 shift was commanded by PCM. Incorrect gear selection depending on failure mode and transmission range selector lever position. Refer to the Solenoid Operation Chart. Shift errors may also be due to other internal transmission concerns such as stuck valves or damaged friction material. May flash TCIL.
P0782, P0732, P0733
PanthersFBMama
08-12-2012 07:22 PM
kristilynne612
01-14-2010 11:12 AM
centralvalleyequip
12-15-2006 10:32 AM
