advance piston adjustment question
Old 08-06-2008, 07:22 PM
j tate's Avatar
j tate
j tate is offline
<!-- / icon and title --><!-- message -->
i have two ip's and the cam that pushes the arm for the advance pistons are in different spots. one pump is off a 6.9 and you have to move the throttle a good bit before it even makes contact with the advance piston, and the other one is off a 7.3 and it doesnt have any slack at all in the adjustment. as soon as you move the throttle its pushing in on the advance piston and i think that its even pushing in on it even at idle position. how is it supposed to be adjusted (with slack or no slack)?
Old 08-06-2008, 08:38 PM
a711112a's Avatar
a711112a
a711112a is offline
from what i understand injector pump adjust ment are best left to a professional who has the training and right testing equipment
the last thing you want is to put that pump in and have a un stoppable run away truck
Old 08-06-2008, 09:18 PM
j tate's Avatar
j tate
j tate is offline
oh no im not putting the pump in, im just trying to figure out why theres such a big difference in the adjustment between the two. also i was under the empression that the engine had to be at a higher rpm before the arm even started to push in on the advance piston. the reason im trying to figure this out is i put this engine on my timing meter to see where the timing was and adjust it accordingly, but the ip is all the way bottomed out to the passenger side and the meter is still saying it has to go some more. im trying to see if maybe the previous owner had messed with it and this is my whole problem.
Old 08-06-2008, 09:47 PM
David85's Avatar
David85
David85 is offline
Messed up timing won't cause a run away.
As to your question, I'm a little curious about that myself. I do know that the 7.3 had the injectors pulled up slightly in the prechamber, so that could account for some of the timing difference between the two engines. But I can't really say for sure if this is the only reason.
Old 08-06-2008, 11:31 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
The 7.3 IP sounds like a pump with less wear.
And I think you are seeing the effect of wear on the cam and linkage.
The 7.3 IP sounds like it should look on both pumps.
My guess is the IP drive gear is off a tooth on your truck..
Old 08-07-2008, 05:34 AM
Dieselamour's Avatar
Dieselamour
Dieselamour is offline
Step 72 of assembly says"Put throttle shaft in idle position, squeeze throttle shaft and face cam tightly toward each other (using .005-in/.127mm feeler gauge) and rotate face cam so lower roller rests approximately in middle of low idle step, tighten screw to 30 lb-in". Hope this helps.
Old 08-07-2008, 06:34 PM
j tate's Avatar
j tate
j tate is offline
fjb2c everything sounded really good only if i knew what everything was. loli think i might need some pics if any body has some.
Old 08-07-2008, 07:00 PM
j tate's Avatar
j tate
j tate is offline
ok i have another question. i have a snap-on mt1480 digital timing meter, using the #1 cylender and set at a 20* offset i can hold the throttle at 2000rpm and have the meter read -0.5 and move the ip and i can get it to read just 0.5 (no negative). which reading am i looking for at 2000rpm (-0.5 or 0.5)? i have it set at -1.5 as of now and that is a 1/4 of an inch to the passenger side of the scribe marks. the truck has alot more power than it did but the fuel mileage is unbearable. i can put it back the way it was but the truck has no power but the fuel mileage is better. im kind of looking for power and fuel mileage if thats possible, but i know beggers cant be choosers.
Old 08-11-2008, 06:22 PM
j tate's Avatar
j tate
j tate is offline
ive asked these questions several times and i guess theres just nobody that can answer them, if theres anybody that can answer the timing questions that i have please.
Old 08-11-2008, 11:19 PM
Dave Sponaugle
I would love to answer your question, but I am not at all familiar with Snap On timing meter.
My guess would be that -1.5 is 1.5 degrees before TDC.
And .05 would be .05 ATDC.
I am running about 10 BTDC, but mine is not exactly stock.
Yes, I have black smoke
Yes, I have power
Yes, it sucks down the fuel
Old 08-12-2008, 06:05 AM
Dieselamour
PM me your email and I will attach a jpeg.
Old 08-12-2008, 03:16 PM
Dieselamour
I have a photo posted
Old 08-12-2008, 03:25 PM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
Where is the photo tho? I don't see nothing...
Old 08-12-2008, 03:49 PM
Dieselamour
its in my gallery
aussiecowboy
06-19-2013 08:47 AM
Bad Bad Leroy Brown
11-02-2012 02:28 PM
Crew_Cab_78
10-26-2009 02:25 PM
super 6.8
1983 - 2012 Ranger & B-Series
07-22-2007 03:17 PM
beardo
03-31-2001 08:54 AM
Quick Reply: advance piston adjustment question
