49 Throttle linkage
Old Jun 18, 2013 | 09:11 PM
aussiecowboy's Avatar
aussiecowboy
49 Throttle linkage
The F3 is finally running, even if it isn't driving yet. I have noticed though that the throttle is only getting about 3/4 travel. This is partly due to what appears to be a very strong return spring on a fairly weak throttle actuating arm, the arm seems to open the throttle only so far before starting to flex. Secondly there is quite a bit of wear and slack in the ***** and sockets on the linkage between the carb and the throttle arm. Not sure what I can do about the arm but is there anywhere I can buy a new link and ***** to go between the carb and arm, this might at least take some of the slack out of it, an adjustable link might be even better? I'll attach a pic of my setup to try and make sense of this.
Old Jun 19, 2013 | 08:47 AM
AXracer's Avatar
AXracer
Holly used to sell a lot of linkage components, but I haven't looked in quite a while. Might check Summit and/or Edelbrock. If you aren't going for 100% OEM, you could swap the ball and socket for a small heim joint. Do you have a large hobby shop that caters to Radio control model airplane fliers? The larger planes use some pretty useful and well made control linkages from quick connects to sleeved cables of various diameters and stiffness, and the prices are reasonable.
Roamer
Feb 2, 2011 06:29 PM
nairod
Oct 2, 2007 10:55 PM
Heavy460
May 10, 2007 08:00 PM
himmelberg
20
Mar 29, 2005 10:46 PM
CodaSmog
Apr 21, 2003 03:19 PM
