1995 Ford F350 Transmission Problems
Old 08-02-2008, 04:47 PM
pappi's Avatar
pappi
pappi is offline
I have a 95 F350. It has the 460 engine with 4OD transmission. It has been shifting very hard from 2nd to 3rd. The rpm's will go up to 4500 before it will shift. All other shifting is normal and smooth. I changed our the transmission filter and fluids this morning, The shifting is not as pronounced as before but is still there. This transmission is only had 2000 miles on it. The transmission pan, and small amounts of metal at the magnet. Nothing I would be to concerned about. Anything thing else that anyone can think of? Oh by the way the truck has a 12inch lift. Maybe that has soemthing to do with it, not sure.
Old 08-03-2008, 02:04 AM
gweeds's Avatar
gweeds
gweeds is offline
Do you have huge tires and stock gears?
Old 08-03-2008, 11:56 AM
pappi's Avatar
pappi
pappi is offline
I have 36-16.5-15. I believe it has stock gears.
Old 08-03-2008, 12:33 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
did you drain the convertor?
Old 08-03-2008, 02:07 PM
pappi's Avatar
pappi
pappi is offline
No i didnt do that. I will give that a shot.
Old 08-06-2008, 08:37 PM
pappi's Avatar
pappi
pappi is offline
I am wondering. Since the truck has a 12 inch lift. I have a Dana Rear end. If the main pinion is not getting enough oil. I have heard that if that is the case if would also cause the truck to shift hard from 2nd to 3rd, anyone else heard this. One more thing Were is the speed sensor located. I want to make sure there is no metal on it. Since if there is is, this also might cause the transmission to shift hard.
Old 08-06-2008, 09:24 PM
lv2race's Avatar
lv2race
lv2race is offline
Do a full trans flush by disconnecting the line at the cooler. Get 4 gallons of fluid and 10' of clear tubing and cut in half. Connect to the lines and put the other end into a large plastic pan. Start truck and let run for 30 seconds and shut off. Estimate amount pumped into the pan and fill trans with that amount. Repeat until fluid is red like new. Piece of cake and should take about a half hour.
Richard.Parker
1997 - 2003 F150
12-19-2014 07:50 PM
49fordv8f4
10-14-2014 08:43 AM
fishernut
1999 to 2016 Super Duty
06-06-2014 05:42 PM
66f100prostreet
10-29-2009 12:03 PM
scottw1
01-16-2009 04:17 AM
Quick Reply: 1995 Ford F350 Transmission Problems
