Rear Tank
Old 07-29-2008, 05:21 PM
JethroF250's Avatar
JethroF250
JethroF250 is offline
Rear Tank
What all is involved in removing the rear tank on a 95 f-250 diesel? Mine is rusted through and needs replaced
Old 07-29-2008, 06:10 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
remove the spare tire. remove 4 bolts from the skid pan/tank pan then unhook 2 fuel lines (requires a special spring lock tool available at most parts stores) and one electrical connector.
hardest part is the fuel lines.
Old 07-29-2008, 06:32 PM
BlueMule's Avatar
BlueMule
BlueMule is offline
and depending on whether or not you have an OEM or aftermarket receiver hitch you may have to remove it. Mine's aftermarket and there's not enough room for the tank to drop between the sideplates.. Of course I didn't discover it till the tank was loose and wedged between the sides of the hitch.
Old 07-29-2008, 07:02 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Old 07-30-2008, 09:06 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
i have the tools you will need, just call when you need them
Old 07-31-2008, 05:59 PM
JethroF250's Avatar
JethroF250
ok i got a florida trip comin up in a few months but i still want to fix the tank cause runnin on just the front is gettin kinda old
