please help! clutch bracket problem
hey i have a problem: i am trying to fix and remove the clutch bracket and I have a broken nut underneath that was supposed to be welded to the frame but it broke and the nut on top of the bracket is stripped this needs to be loosened, adjusted and tightened again and I cannot get a wrench in there please help if you can, any suggestions? the truck is a 1977 -f150 2wd 300ci
I know what you're talking about - had to loosen mine awhile back to replace the bushings and felts, but the nuts were not welded to the frame - they are steel locking clinch nuts, and need to be backed up or they will spin. I don't remember them being that difficult to get to, though. Of course if the bolt heads are rounded off, then they could become a challenge, but I'd visegrip the bolt then instead and ratchet off the nut.
jukebox61
26
01-28-2014 09:30 PM
1fixitman
07-15-2013 04:35 AM
nothercrash
12-10-2011 07:36 PM
ratwell
08-16-2003 11:02 PM
