cracked radius arm bracket
Old May 14, 2004 | 12:11 PM
doc300's Avatar
doc300
96 F-150 4x4 has a cracked right side radius arm bracket. I have a new bracket and the bushings to install. A friend of mine has replaced his bracket and bushings and told me that this can be done without jacking up the truck. Is this true? He said just remove the 1-1/8 nut, take the bolts out of the bracket, slide the old bracket off, put the new on, bolt up and your done. Is that all there is to it?
Thanks in advance.
Old May 14, 2004 | 02:27 PM
underDAWG's Avatar
underDAWG
No, you don't need to. But it is easier to jack up the truck and take the wheel off so that you get more room to with with. HTH.
Later,
Old May 15, 2004 | 09:37 PM
CGreene's Avatar
CGreene
you have to cut out the rivets for the bracket though.
Old May 17, 2004 | 07:17 AM
doc300's Avatar
doc300
Thanks for the help. Passenger side was bolted on. Took about 1- 1/2 hours to change. No major difficulties.
Evan_P
Mar 25, 2012 02:19 AM
Fomhoire
1983 - 2012 Ranger & B-Series
Feb 19, 2006 10:59 AM
Clubwagon
May 31, 2005 09:13 PM
f150lariat
Jul 15, 2004 01:00 AM
Chris Custer
Jul 10, 1999 03:39 AM
