Rear drum brake diagram
Old 05-21-2008, 08:43 PM
Thompy's Avatar
Thompy
Thompy is offline
I have a 2001 Ranger 4x4 off road w/ 10" drums and I'm having trouble getting the brakes back together. Both sides had the self adjusting cable broken which didn't give me an idea where the bottom springs attach to, as they broke and flying around in the drum. Does anyone know where I can find a diagram of the brake drum assembly? I looked through the forum here and found a good thread but the links weren't working.
Thanks,
Adam
Old 05-21-2008, 08:52 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
Here's a few diagrams off the Autozone website, maybe they'll help:
AutoZone.com | Vehicle Selection - Year
Old 05-21-2008, 08:58 PM
Thompy's Avatar
Thompy
Thompy is offline
I have that photo in my manual but that manual only goes to 2000 must have changed the drum brakes in 2001. My dad took all the springs off before I could take a picture or at least be there to see where all the springs go, thanks my delima. Need to know how the self adjuster operates, but having a hard time with broken parts and bad luck.
Old 05-21-2008, 11:15 PM
herman391's Avatar
herman391
herman391 is offline
Will this one work, I know it's not to detailed but you never know...
http://i250.photobucket.com/albums/g...91/Graphic.gif
Old 05-22-2008, 04:23 AM
pgw85706's Avatar
pgw85706
pgw85706 is offline
Have you seen this from the tech info stickie section. It is not your vintage, but I think there have not been any changes to the fundamentals of rear drum brakes and it should apply to your model. The self adjuster simply rotates to index and expand the adjusting screw as the shoes wear.
http://members.aol.com/racsan99a/RearBrakes.doc
Old 05-22-2008, 07:04 PM
Bikeitswift's Avatar
Bikeitswift
Bikeitswift is offline
I don't know if this 93-94 illustration from Haynes helps at all, but here 'tis...
rico56
17
02-24-2017 04:09 PM
1966 F-250
11-08-2016 07:25 PM
jmikeyj4
08-14-2016 04:15 AM
tonyford
Escape & Escape Hybrid
10-07-2012 08:31 AM
salewit
13
04-12-2005 02:25 PM
Quick Reply: Rear drum brake diagram
