93 ranger power windows don't work
Old May 22, 2008 | 09:19 PM
ozzy460's Avatar
ozzy460
93 windows quit one day, both at same time, been down for a year, any ideas or should i just convert to manual?
Old May 22, 2008 | 10:32 PM
Hank85713's Avatar
Hank85713
could be the switches or the relays. Do they do anything at all? Did you check the fuses? if all else fails you can go direct from a hot source and see if they go up that would put you into checking the above. Use a continuity tester to check the switches, easiest is to check for 12v at the wire harness with the door panels off, then 12v at the switches. if no power at the 1st check point go for the relays/fuses. also make sure to check the grounds for good connection.
jte1998
Jan 12, 2017 09:01 AM
Joshs 93
Jul 6, 2016 08:21 PM
bf5113x
Oct 19, 2015 07:02 PM
boggerted
Mar 18, 2010 02:32 PM
DuallyDad
All Things Towing
Oct 23, 2004 01:36 AM
