Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #16 (permalink)
Old 05-16-2008, 07:24 PM
c00nhunterjoe's Avatar
c00nhunterjoe has a good reputation on FTE.c00nhunterjoe has a good reputation on FTE.
ah i like that name, also thanks for the add, i feel bad for not mentioning that now
__________________
97 F-250, 4.10's Auto, Superchip, All mods by c00nhunterjoe's performance shop http://community.webshots.com/user/c00nhunterjoe
http://youtube.com/c00nhunterjoe
  #17 (permalink)
Old 05-16-2008, 08:09 PM
luthrobediesel is starting off with a positive reputation.
one time i dropped an oil pump drive shaft into the oil pan and left it on a 330 medium duty. then i got one from advance and it was too short and i didnt realize it and started it and wondered why no oil pressure. figured it out that they gave me the wrong one and now the engine has a deep thud after after warmed up prolly wiped out a main bearing, or a 6 inch rod getting thrown around in the oil pan
  #18 (permalink)
Old 05-16-2008, 09:13 PM
tjbeggs's Avatar
Fisher of Men
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
I would use the magnet. The strongest one you can find. The tappet would have to jump thru the oil 6 inches, thru the wind age tray to reach any moving parts. Or pull the engine to get the pan off. Or what I might consider as well, cut a 3 inch hole in the side of the oil pan. retrieve the part and patch the hole back up.
__________________
Tim
Proud User of "The Cure"
For sale- 95 accelerator pedal, Gray interior and dash part, cab and more PM your request!
Click the Picture for wiring diagrams, tech info and Pictures!
  #19 (permalink)
Old 05-17-2008, 07:41 AM
Todd525's Avatar
Todd525 is starting off with a positive reputation.
Quote:
Originally Posted by Robbgt View Post
I'm PISSED I didn't remind him of that! I was almost 100% sure it was in that post with the original directions................
Thanks for the Props Todd, just wish I could have helped him out better...-Robb
Not a problem. I did a quick search on here and found a few posts that didnt mention this step. He may have run across one of these. Who do we talk to about getting a "HOW TOO" section started. I think it would be helpful if we could get these things posted. Have everyone have access to it, and post everything that you did, and all the things you could have done differently to save time and make it easier. Everything from Fuel pumps, CPS, power windows, brake controllers, etc... Just keep people from posting in that topic to keep it uncluttered maybe??
Quote:
Originally Posted by Hussler View Post
Where where you when the question was asked? I too did the search on the lift pump and also raised it by rotating the engine.
I know, I know. But greatness is so hard to achieve, and I hate to spend all of mine on just this ONE forum!!!!!
__________________
96 F350 CC Dually PSD. Tuner, straight pipe, 6637 filter, ribbed diff cover, 12.7k mod, 28k tranny cooler, 3 plate TC, autometer boost, trans, and pyro. Used 4 Car Haulers, 5th wheels, goosenecks, Fat Chicks.
01 F250 CC 4x4 PSD. SOLD.....Kinda missed already, and its Day 1.
  #20 (permalink)
Old 05-17-2008, 08:34 AM
MADVAN is gaining momentum as a positive member of FTE.
CHIT!!!
I would spend the time to fish it out the dipstick.
The mag way is OK, just not for me.
Bill
__________________
97 4X4 PSD Quigley
Supporter/End user of ShiftSolutions The CURE E4/4R Trans Control. Helping Cancer patients and families. www.fordtransmissioncure.com Video of No OD Bump/Slip Shiftpoint
Special thanks to RacerX www.racerxautomotive.com
  #21 (permalink)
Old 05-19-2008, 06:34 AM
Stroker09's Avatar
Stroker09 is starting off with a positive reputation.
i got a 250lb pulling magnet from harbor freight and stuck it on there. Its pretty strong. I dont think it will hurt anything to leave it down there for alittle. I plan to cut a hole in it and weld a patch on or something. I was pissed when that dropped in there. Just glad it didnt hurt anything. Other then that little mess up the pump went in great. I can even notice a difference in power and some more smoke. Thanks guys and dont worry about not telling me to turn the engine by hand. No big deal. But may i ask. How do you turn it by hand?
Thanks
__________________
97 F250 PSD. Intake. 4in exhaust. 3in downpipe. Fully built tranny, boost, trans temp and pyro gauges...not a bad set up for a 17 year old. lol
  #22 (permalink)
Old 05-19-2008, 07:54 AM
Action4478 is gaining momentum as a positive member of FTE.Action4478 is gaining momentum as a positive member of FTE.
Quote:
Thanks
I also read some where ,,, someone drilled out the drain plug hole a bit more ,,removed the tappet & used a repair kit for the oil drain...
__________________
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
  #23 (permalink)
Old 05-19-2008, 07:59 AM
I'm PISSED I didn't remind him of that! I was almost 100% sure it was in that post with the original directions. When I did my pump, i un-bolted it, rattled it a bit then cranked the truck over by hand until the pump started to lift itself out of the hole. then you know the lobe it at the top and there is almost no way it can fall down. I'm sorry man
-Robb
I tried this on mine ,,,it was stuck ,,,, or ,,,the tappet isn't designed to be longer than the stroke..
I have heard it said many times ,,but never heard of anyone doing it & having it work....
The lobe in the correct position will keep it from falling in...
I also read of a way to know were the right spot is , I''ll see if I saved it...
__________________
Rick.....
  #24 (permalink)
Old 05-19-2008, 08:01 AM
I can't remember where ,, but I had this saved :...
dropped the plunger from the low pressure pump down my motor!
fortunatly it landed in the oil pan, but it was a little to big to fit through the drain hole. so i bought what they call a pan saver, where you drill a new hole in your oil pan, and plug it with a special bolt. that was just big enough to get the plunger out through the bottom.....be careful..
__________________
Rick.....
  #25 (permalink)
Old 05-19-2008, 08:48 AM
Todd525's Avatar
To turn the motor over by hand, just go to the crank bolt with a ratchet, and heave. Your supposed to loosen the fuel pump bolts, knock it around a little to ensure that it isnt stuck, then crank slowly while watching for the pump to rise out of the valley of death. You will see how far it comes up, when it s up, yank it out. Tappet fals down, just grab it with a pair of needle nose pliars. Its not that the lobe has enough lift to keep the tappet INTO the pump, its the fact that with the lobe raised, it decreases the clearence between the lobe and the block enough that it CANT fall thru. Like trying to stuff 10 gallons into a 5 gallon hat, it just cant fit. LOL The end.
__________________
  #26 (permalink)
Old 05-19-2008, 08:54 AM
Robbgt's Avatar
Robbgt is gaining momentum as a positive member of FTE.
Quote:
Action, See Below.
Quote:
Thats EXACTLY how I did it on my truck. I cranked the engine over with a ratchet and had a buddy of mine watch the pump until started to rise a bit out of the hole. They you can grab it and yank it out. I was fortunate enough that the tappet was still in the pump, but had it not I would have been able to fish it out with pliers because the lobe was blocking the it from falling down.
-Robb
__________________
97 F-350 XLT 4x4 PSD, E40D, 3.55's, 153K, 6637, 140V IDM, HPX, FPR Shim, Hotfoot, Tymar DP, Dual Exhaust, T/C Lockup mod, new GP's, Stancor GPR.
>>FOR SALE: FTE Classifieds<<
  #27 (permalink)
Old 05-20-2008, 07:07 AM
Stroker09's Avatar
I think a How to section is needed lol. With good detailed directions. I know it would help me with other things. I found this thing online that you drill into your oil plug and it makes the threading bigger and comes with a bigger bold. I think it might work cause it would make it big enough for the tappet to fall through with out cutting apart the oil pan or pulling the engine. Learn from my mistakes and in sure alot of other peoples. Crank the engine by hand first lol. Im not to mad about it though. As long as it doesnt touch any moving parts its all good. Ill get it out of there some how.
Steve.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
