1997 5 speed with no reverse
Old May 20, 2008 | 08:30 AM
fire7882's Avatar
fire7882
I just bought my first powerstroke from the local bank. It was a repo and the reverse dosn't work.
The shifter will go into the reverse position but nothing happens when you release the clutch. 5th gear also grinds a little but nothing serious.
Any ides as to what might be wrong and is it worth repairing or should I get a used trans from the junk yard.
Are gas zf5s and diesels zf5s the same?
Old May 20, 2008 | 09:31 AM
farmert's Avatar
farmert
The bolt patterns are different on a gasser trans. than on a diesel. They won't bolt up. You need a trans. from a diesel either from a stroke or an IDI will work from what I've been told.
