big big problem need help ASAP!!
It may have made it all the way to the oil pan. The only way to know is to drain the oil and use magnet or wire trying to drag it to the drain hole so you can verify it.
Rotate the engine by HAND ONLY until it falls into the oil pan.
Glue the magnet permantly to the oil pan so it can keep the tappet from moving around.
x3 Ouch man. I'm sorry to hear that... the directions that I posted for you should have had this part in bold.... What these guys said should work, good old magnet glued on there to hold her in place
-Robb
PART 2
Remove the two 10 mm bolts holding down the pump and carefully remove the pump from the crankcase bore. It will take some twisting and pulling. Be careful here so as not to lose the tappet into the cam crankcase. That would not be good. Examine your new pump to see how the tappet connects. Eventually you'll be able to lift the pump straight up and out of the engine.
pulling the thing out i was going to reach right in and make sure it didnt fall down the secound i could of got my hand under it but like the tappet didnt come out with the lift pump. the pump came out and all you heard was tink. how strong of a magnet do i need and how the hell do i find it in the oil pan?
nope. all you see is the thing it sits on. I found it down in my oil pan. i can put my pinky in the screw whole and feel the side of it. So just get a big boy megnet and glue it on there? thanks guys. Sorry i just freaked alittle. never dropped something in there before lol
I bet this had occurred many times in different repair shops. My guess is they just leave it in the pan and no one is the wiser. I really can't see how it can hurt anything just laying in the bottom of the pan. I've never heard anyone indicate they destroyed the engine by not removing it, although I've never had that pan off to really see how much room is in there, nor am I a diesel engineer.
Your supposed to crank the motor over by hand to move the lobe into the raised position. This eliminates any and all possibility of it falling into the crank case/oil pan. Kinda the problem for this site. Everyone knows the basics, and only a few know the tricks. What we need to do is start a step by step how to section that has instructions looked over from guys like Coon, TJ, Madvan, Kawa, Robbgt and such. Most of them have the pics that show, and they all have the tricks up their sleeves.
Thanks for the Props Todd, just wish I could have helped him out better...
-Robb
Where where you when the question was asked? I too did the search on the lift pump and also raised it by rotating the engine.
