PMGR starter upgrade
Old 04-30-2008, 07:16 PM
Thunderjet4x4's Avatar
Thunderjet4x4
Thunderjet4x4 is offline
Well, the stock style starter(76 460 auto) began grinding, or not releasing, took it apart-way worn. Locally best deal I could get was my old starter rebuilt for $90 + tax. Then I did some research here and on google, finding out how to retro a pmgr(permanent magnet gear reduction) starter from a 92-97 7.5 auto F-250-which have a nice gear reduction, permanent magnet motor-more torque, less power needed! Local wrecker wanted $100 + tax for used, altho they lost the last one they had...
Local rebuild of the new type starter was 180 + tax..
Rather disheartened, I ended up checking ebay, found a new one for $50, very nice quality-works like a hot damn! This new starter, delivered to my door, cost me $98 including tax and shipping! Even has a 1 year warranty.
I was worried about the fit, it bolted in with the stock bolts no problem, half the weight of the ol bugger too! Only odd part was hooking up the second wire, 10 guage, for the solenoid. The rest was easy, swapped the main power wire to the batt. side of the old solenoid, ran the 10 guage wire from start side of solenoid to the new starter solenoid. I also cleaned all of my battery connections and grounds, hooked up the battery, and....
The new pmgr starter rolls over my ol 429 with authority! Sounds strong-like there is a beast being awakened!
Really happy so far, hope the starter lasts-which Im sure it should.
Old 04-30-2008, 08:13 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
I just bought one of those off of eBay, too. Mine was $50 as well so I bet we got it from the same guy. I have mine bolted up but I haven't ran the motor yet because I'm working on other things; but I'm glad to hear the good news! Looking forward to running mine. Thanks for sharing!
Old 08-27-2014, 11:08 AM
96red4.9's Avatar
96red4.9
96red4.9 is offline
Will that type starter work on a 400 with a 4 speed as well?
Old 08-27-2014, 11:17 AM
96red4.9's Avatar
96red4.9
96red4.9 is offline
Orielly's shows that an original starter has 9 teeth on the gear and a 97 f250 with the 7.5L has 10 teeth. Will that be an issue?
Old 08-27-2014, 12:05 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,290 Likes on 2,446 Posts
I read here that is a yes.
One other neat little item you can use on your 429/460 is a 92-93 7.5L F-Series gear-reduction starter. They are smaller, weigh less, and have more torque than the standard full-size Ford 351M/400/429/460 starters. If you plan to install headers on your Bronco with a 429/460 engine, then the gear-reduction starter will give you a little more room to work with in a cramped engine compartment. You can purchase these starters from most auto parts stores for around $200.00.
Scroll down to Starters and Distributors
ProjectBronco.COM! A 78-79 Ford Bronco Resource Center
Old 08-27-2014, 12:15 PM
96red4.9's Avatar
96red4.9
96red4.9 is offline
I believe I read that from another post. I can't find anything that specifies the compatibility for a truck with manual or automatic and if either one will work on the other. The automatic and manual have different part numbers. I do not know what the difference would be. Both type transmissions have 10 tooth gears where the original has 9. I suppose if I have a manual trans now I should buy they new starter for a manual trans application.
Old 08-27-2014, 12:19 PM
77&79F250's Avatar
77&79F250
If you ask the parts store for a 92-93 or (97?) 7.5L F-Series gear-reduction starter, do they ask if it for a standard or automatic trans?
Keep us posted on what works, I a really interested in getting my 460 to crank over faster.
Old 08-27-2014, 12:33 PM
96red4.9's Avatar
96red4.9
96red4.9 is offline
I have only looked online at O'Rielly's site which asks if the vehicle is manual or auto and shows different part numbers for each. I have read it works on a 460, which has the same starter as a 400. What I have not read is if it works for manual or just automatics. I will provide a definitive answer once I know unless someone can beat me to it!
Old 08-27-2014, 12:54 PM
96red4.9's Avatar
96red4.9
96red4.9 is offline
Manual Trans Mini Starter, SALE!!!
I think I found the answer to my question at the above link! $69 with a two year warranty!
Old 02-19-2018, 03:54 PM
Luvmy66t's Avatar
Luvmy66t
Luvmy66t is offline
Pmgr 10 tooth work on 9 tooth applications?
I have an 87-e350 that had a dd 9 tooth starter installed. Is there an upgraded starter available for this? I’m having issues finding one. I see the pmgr from the 93’era 460 being referenced as an upgraded starter...but will it work on the 9 tooth application?
79 ranger 4x4
05-30-2017 12:37 PM
hivoltj
03-13-2016 06:28 PM
AtlM5
12-13-2015 07:57 PM
wotan
13
06-30-2015 08:56 AM
Tyler S
27
06-19-2015 09:09 AM
Quick Reply: PMGR starter upgrade
