Excessive Smoke While at idle
If it smells like diesel fuel, it means it isn't being burned as normal.
It can mean the engine temperature is low, or the spray pattern from the injectors is not fine enough. Also if the compression is down.
There are several things that can cause a diesel to not burn the fuel properly.
Diesel engines used to put out a lot of smoke that smelled like unburned fuel when they first started. They did that until the engine temp came up.
Workin F350
07-09-2020 08:33 PM
Mwydro
05-04-2008 09:31 PM
kitsapcountychopper
25
03-19-2004 08:11 AM
DannyP
03-23-2001 11:07 PM
