Excessive smoke
Old Feb 6, 2010 | 10:56 PM
2001400ex's Avatar
2001400ex
Excessive smoke
Just want a an answer from ya'll. This is what my truck looks like in the morning, these two mornings it was foggy with a high moisture content of course. Basically it smokes a little, then when it goes into the stock high idle, I get this. I do not have a cat. When I start going, there is no more smoke and when I leave work and it is 45 degrees out, it only smokes a hair, nothing like this.
So... excessive? or normal?
Old Feb 7, 2010 | 07:09 AM
1954oldred's Avatar
1954oldred
Some of the Folks who are running the SCT have reported some smoke upon initial start up, depending on the tunes You downloaded. Try returning to stock and see if it still smokes. Are You running 2 stroke oil in the fuel? Mine smokes a light blue smoke upon start up when I run the 2 stroke. Use your SCT to check for any DTC's also. Hopefully You don't have a turbo seal going bad or an injector issue.
Old Feb 7, 2010 | 12:07 PM
2001400ex's Avatar
2001400ex
No two stroke oil, that only goes in my snowmobile. LOL I do use Diesel Kleen every tank, white bottle this time of year.
The program I am running is from Innovative and it is a normal street tune, nothing excessive. The only DTCs are from my EGR delete, the normal two, I checked the other day.
I hope I don't have either either. It does not rough rough on idle, only extreme cold start, like zero degrees. I hear an injector causes a rough idle. My boost is very normal, gets to 29 when towing and have it pinned up a hill. Other than that, does not really get over 20 psi. It runs great now, just want to ensure that amount of smoke is not indicative of a bigger issue yet to come.
It is out of warranty so I hope there are no injector issues.
Old Feb 7, 2010 | 12:51 PM
1954oldred's Avatar
1954oldred
I am in no way putting down SCT or ID, try it back on stock setting for a couple of starts just to see if it clears up the smoke. If that is it then You could talk to the folks at ID if it is still a concern, some here have spoke of the same scenario once they remove the tune and go to stock or vice versa. Our trucks injectors like the lubricity that 2 stroke oil provides, helps a bit w/mileage also.
Old Feb 7, 2010 | 01:29 PM
jonr78's Avatar
jonr78
My truck dose the same thing I am about to take it back to the shop I will let you know what they say.
Old Feb 9, 2010 | 10:25 PM
06NEWTOME's Avatar
06NEWTOME
Mine is the same way and would like to hear more on this one.
06 cc psd 76k on it
Old Feb 10, 2010 | 12:32 AM
9228.bobcat's Avatar
9228.bobcat
When you drive it when it is smoking like that and if you lift of the throttle does it seems to puff out more smoke?
Old Feb 10, 2010 | 08:56 AM
2001400ex's Avatar
2001400ex
I haven't taken the tune off yet. But after I start driving, the smoke goes away immediately, no puffs after letting off throttle or anything. Of course the engine is cold so I baby it the first 10 minutes or so.
Old Feb 10, 2010 | 01:50 PM
jonr78's Avatar
jonr78
Mine is the same also as sooon as I start driving it goes away but after it sits for more then about 4 hrs it is smokey and smells like fuel I just got it re flashed 1000miles ago and that my have helped for a day. I dont run any tunes on my truck.
Old Feb 10, 2010 | 02:37 PM
Jarvis250's Avatar
Jarvis250
My truck does the exact same thing, when it is cold outside. a whitish smoke idleing in the morning, then goes away quickly once i start driving. I'm not saying this is normal, but I have not been the least bit concerned about it. The truck has been flawless for the first 50K
Old Feb 10, 2010 | 08:48 PM
devink's Avatar
devink
I have never heard of adding 2 stroke oil to the fuel......how much do you add, does this work the the 7.3 as well?
Sorry to get away from your issue.
Old Feb 10, 2010 | 10:21 PM
2001400ex's Avatar
2001400ex
Some people swear by it, I have never tried it. Check out the tech folder as I am sure there is a thread in there about it.
Mine whistles a little as well when the high idle kicks in.
Old Mar 11, 2010 | 07:15 PM
Jarvis250's Avatar
Jarvis250
2001400ex, have you had this diagnosed yet or have any further details?
Old Mar 11, 2010 | 08:38 PM
steelhead2's Avatar
steelhead2
that looks way to heavy to be normal morning condensation type smoke. looks like an injector might be on the way out?. thats exactly what my 04 did when the egr cooler went out, but yours is gone.
Old Mar 11, 2010 | 09:54 PM
cheezit's Avatar
cheezit
my advise is stop the 2stroke oil, return the truck back to the oem tune, and try it. also test fuel pressure and perform any repairs reqired to get that inspec. test the ficm voltage. ohm out all the glowplugs (do not use a test light) if all that is good then most likly an injector concern.
