You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
If you do not remove the Methanol first; 2% by weight. I recover the methanol first, then filter out the soap, then use only 1% by weight.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
will magnesol remove the water in the oil as well? i am having a problem dewatering my oil and my water in fuel light keeps coming on in my truck? I also have recently been informed that all my methanol is not getting out of my bio either. could maybe i don't have water and it is the extra little bit of methanol cause my light to come on? i am trying to make some good bio and am thinking of switching to magnesol. thanks
Don:
Are you filtering your Magnesol out or running a centrifuge? I have been filtering first with gravity through socks and then pulling the fuel by vacum through 1 micron Biotek filters. It works, but without pressure (since I am using vacum) the filters stop flowing too quick. I am debating buying a Dieselcraft centrifuge or a bag filter housing.
Your thoughts are appreciated.
PS: I use 2 grams/liter after removing methanol.
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP exhaust, 6637 intake mod, Dieselsite 203 thermostat, Airdog II electric fuel system with fuel bowl delete.
Don:
I filter out the Magnesol. I use 3 filter housings, and an air powered diaphragm pump to force it thru them. The first is 50 microns, it then goes directly to a duel 10 micron setup with a pressure switch, and a electric valve. When the pressure increases to a preset level the pressure switch opens the valve and diverts the bio to the second filter automatically and lights a red light that lets me know to switch out the first filter. After I've filtered to 10 microns I run the whole batch through a 5 micron, then a 1 micron absolute. I've found a used continuous centrifuge for sale at $2,500 and may buy it and switch over. Still trying to justify the $$$$$
__________________
