3.8 throttle body cleaner problem
anyone had any problems after using throttle body cleaner? i used some yesterday and didnt start my car til a couple hours later....it wouldnt idle, then i had no takeoff power.....then it was real sluggish when i stomped on it down the road....did same thing today?????????????
where exactly did you spray the cleaner in or at? i never had a problem i always use the CRC brand throttle cleaner it works great remember if spraying directly inside the TB make sure engine is on & make sure some1 can rev it a lil to make sure you dont drown it. if you spray it when off it can take a while to turn on or idle properly cuz the cleaner just sits there... check the IAC maybe got penetrated let it dry out or take it off & clean it with Thr. cleaner
just my 2cents..
just my 2cents..
