f-450 hydro-boost fluid ?
hello. i just got a 90 hydro-boost installed and ready to put fluid in the power steering pump and am needing some help on the best fluid that will work the best. thank you for any input on this. and i will let you know how it works out. murrhee 86 f250 ext. cab 4x4 reman. 6.9 turbo auto 410 gears. ps dave s. all them part # fit like a glove thanks.
I used synthetic power steering fluid in mine.
Valvoline Syntec was the name I think, been a while since I installed it.
Glad the install went well for you.
After you fill it with fluid, take a short drive.
Do the full to lock left and right turn at least twice to each side and a couple stops.
Then check the fluid level again.
After you get all the air out of the steering pump side, I think you will be very happy.
hydro-boost fluid?
thanksPLC7.3 and Dave S. i took the truck for a test run after i got home from work tonight and was amazed at the braking on this truck now! but i have a trail of fluid out my drive way, looks to be coming from the presure conection into the steering pump, looks like the original line has an o ring and the new one dont, once i fix that looks like some real sweet brakes. thanks agin. murrhee 86 f250 ext. cab 4x4 reman. 6.9 ast turbo auto 410 gears
The new line should have had an O ring on it as well.
Rather easy to knock it off the fitting when you are installing the line given the proximity of the inner fender.
If someone pulls out in front of you, I hope you wear your seatbelt.
If you jump on the brakes like you had to in the past, it is going to hurt when you kiss the steering wheel.
hydro-boost fluid?
hello,and i am real pleased with the brakes now. and i fixed the leak i had by stopping by the wrecking yard and getting a 1990 part that the line screws into in the power steering pump. real easy fix.that is a great fix for an 86 f250 diesel
if you haul heavy loads, i am 110% sasified. thanks. i down loaded photobucket and as soon as i figure out how to post some pictures of it i will. murrhee 86 f250 ext. cab 4x4 reman. 6.9 ats turbo auto 410 gears
nonrev321
04-28-2016 04:45 AM
murrhee
10-23-2007 09:19 PM
