'95 351W Charcoal Canister Vacuum Line Goes Where?
My '95 F350 351W charcoal canister does not have a vacuum line attached from the engine side and I would like to hook it up. I've read 1995 doesn't have a canister purge solenoid, instead the vacuum line comes right off the throttle body. The problem is I only see one port available off the Throttle Body and that vacuum line goes to the MAP sensor.
Can I just put a Tee into this line and use for both MAP sensor and Charcoal Canister? Is that how it's supposed to be? (anyone want to peak under their hood?)
Thanks...
Thanks...
pickncrew
04-06-2008 05:45 PM
pickncrew
03-17-2008 10:34 PM
pickncrew
03-16-2008 09:04 AM
