why would my truck seem to cut in/out when i push down on it? just started since this chip. but, at the same time is when i had the spring issues. think it could be from un-stable fuel press?
ya i know they cant now. a boy i know says he has a superchip installed on his truck, and his TS chip stacked with that, but i have been told thats Bull
you can have the downloaded tuner installed and a true chip on top of it, probably has some sick low end power but i'm sure a check engine light follows shortly as does some incredible egt's
can't stack chip or tuners. If a tuner used on the PCM then a chip is installed the chi overrides the tuner/pcm. Dude may have it done that way but its not doing any good.
oh, i didnt know. i figured theyd conflict. so if your hpop and injectors are up to par, and you stacked a TW chip with the 120 top mode, and a bully dog with a 75 top mode, would you really have 195 over stock?
no there is only one slot for a chip. when a chip is installed it cancels out any tuner that has a program installed. The only things you can stack with a chip or tuner is like a 10k mod or edge box (glorified 10K mod)
If they are doing it on a Powerstroke they have no idea what they are talking about. Stacking is a Cummins thing mostly cause they have different modules they can use. Some of those aren't really chips just units that up the fuel.
the banks 6 gun tuners and the edge box's can be stacked as well, i had many people come to the dealer with the 6 gun's stacked on top of other chips/tuners. they do work together it all depends on what 2 units you are using. i dont recomend doing it though. everyone of those trucks, while they pulled there ***** off, had serious issues.
