Engine oil pre-lube kits
Old 02-25-2008, 09:54 PM
bignorthford's Avatar
bignorthford
bignorthford is offline
Good day:
I've been doing some research on engine prelubers for my pick up and I was wondering if anyone has one installed and if so, do they like it and does it work. The industry I'm in has engine oil prelube on all the heavy equipment to help protect the engine during startup, especially in the bitter northern winters and I was wondering if that technology is available for my truck. I have a 98 F150 4.6L SC/SB 4x4. Any feedback would be much appreciated.
Old 02-26-2008, 09:32 AM
MrBSS's Avatar
MrBSS
MrBSS is offline
Yes, I put one on my 2001 4.6 (purchased new). That truck has never spent a night in a garage. I felt it would be an advantage in cold weather, particularly with the overhead cams. Also installed a block and battery heater (Ford accessory). Don't know how it'd be without them, but it's always started like springtime, and uses no oil at 145,000 miles.
I don't recall the brand right now, but it consists of a pressure tank and solenoid valve. Works somewhat like a pressure tank on a well system. Previously (on another vehicle), I had one that involved a small pump. I would not recommend that type because the pump didn't last.
Old 02-26-2008, 10:04 AM
bignorthford
Thanks for the response. Did you purchase your kit from a store or off the internet?
Old 02-27-2008, 10:25 AM
MrBSS's Avatar
MrBSS
MrBSS is offline
Got it on the internet... wish I could tell you more, but my manuals aren't available and my son has my truck right now. You might try searching the oil and lube forum.
sunbelt57
07-26-2016 07:14 PM
CrazyCajun
10-05-2015 11:34 AM
ljfen
01-12-2013 09:53 AM
handyhand
1983 - 2012 Ranger & B-Series
03-29-2009 07:46 AM
CLPF350
12-22-2003 05:20 PM
Quick Reply: Engine oil pre-lube kits
