Coolant temp gauge install
Old Dec 21, 2003 | 09:35 AM
CLPF350's Avatar
CLPF350
I'm in the process of installing an A pillar quad pod in my '04 6.0. I can't figure out where to install the sending unit for the water temp. Would someone help me solve this? Is it possible to tap into the original Ford sender wireing? If so would this interfere with the Ford dash gauge? Where in the heck is the Ford water temp sender? I think I have everything solved except this. The gauges are: EGT, boost, a combo tranny and diff temp and a combo oil pressure and coolant temp. For the oil pressure I'm removing the original sender, threading an adaptor into the hole and installing a 300 lb. psi hydraulic hose. The hose will connect to a 4 way adaptor that will hold the two pressure senders and a connection to a PreLuber.
Thanks for the help.
CLPF350
Old Dec 22, 2003 | 11:15 AM
emtabmm's Avatar
emtabmm
Re: Coolant temp gauge install
[IMG][/IMG]
Old Dec 22, 2003 | 05:17 PM
CLPF350's Avatar
CLPF350
emtabmm:
Thanks for taking the time to try to help me with the water temp sender location. I've noticed your signature on many helpful posts. Unfortunately I can't read any of the captions on the picture you posted so in spite of your efforts I still don't know where/how to install the sender.
Many thanks for the effort and Happy Holidays to you and all who spend so much time making this web site successful.
CLPF350
Old Dec 22, 2003 | 05:20 PM
emtabmm's Avatar
emtabmm
ck your email...
treverd
Sep 5, 2016 03:43 PM
jerryparks
Jul 24, 2015 05:42 PM
rodderz
Feb 2, 2015 12:23 AM
kabcpapc
Modular V8 (4.6L, 5.4L)
Sep 6, 2014 05:35 PM
kabcpapc
1997 - 2003 F150
Sep 6, 2014 03:53 PM
