bolting bed to frame?
Received 1,354 Likes
on
on
I put an aftermarket 51-52 bed and rear fenders on my 48 F-3 shortened to F-1. As I recall there were only 8 holes to be concerned with where the bed to crossmember bolts go through the frame. Just weld the holes up and drill new ones, then you can place the bed exactly where you want it. I wanted a little more space between the bed and the cab on my truck so I didn't use the stock holes anyway. The cab had been rubbing against the front panel of an original bed at some point in the past and had sliced a hole in the back of the cab...
drof46
07-12-2009 03:34 PM
Gwilkrrs
17
02-25-2008 07:46 PM
