HPOP o'rings
02-17-2008, 10:00 PM
on
HPOP o'rings
Has anyone replaced the o'rings on the HPOP discharges. If you have how hard of a job is it and do you need any special tools?
02-17-2008, 10:14 PM
our trucks are simple, easy to do, 99-03's use a special service tool for the quick disconnects but you can make one out of a piece of etal really easy
02-17-2008, 10:25 PM
on
in the kit I got from the dealer it says to use brake cleaner, is there a reason for this.
02-17-2008, 10:28 PM
no idea, i would spray any residue off from the leaks but i wouldnt spray the inside of the pump or the o-rings, just wipe it clean
02-17-2008, 10:43 PM
on
thanks for the info coonhunterjoe. I noticed in some of your pictures you have an aftermarket air filter, what brand and number is it? Thanks again
02-18-2008, 08:45 AM
its a duralite partnumner 6637, available for 25-30 bucks at your local napa. i used 4 inch pipe to make the rest of the intake
basstardo
04-24-2017 01:34 PM
Eddie C
74
05-12-2016 06:20 PM
Rhager
1999 to 2016 Super Duty
05-08-2013 09:15 AM
ron's power stroke
20
12-08-2011 02:11 PM
