Fuel mileage on F-150 5.4l
my 05 150 averages about 12 mpg. i get 15 on the highway most of the time. my best was 18 once and only once.it has the 5.4 and is a scab longbox. the 150 is lighter that the 250,so that may help. i drive a 250 at work with the 5.4 supercab and get 15 on the highway also. both are 4x4. hope this helps.
haven't had the opportunity to pull that much yet with mine ( maybe you've just given me my next project lol) my truck is the hd version,it has the 7 lug wheels and 4.10 gears, so pulling that much shouldn't be a prob. i'm not sure how much better pulling power you'll get with the 150. my advise if you do this swap, would be to make sure the gears are somewhere in the 3.73-4.10 range. your 250 is already in this range probably.
on
1 Post
Originally Posted by chetlogan
I have an '08 F-150 Screw, short box, 2wd, 5.4L, 3.73 diff, RoushCharged, gets 16.5 mpg overall driving. Tank in and tank out. And that's with our 10% ethanol blend. On 100% gasoline anywhere, I'd probably see 19 mpg over all. Ethanol results in 15-20% worse mpg.
CW
CW
Ethanol is a terrible fuel for combustion engines because it is hydrophillic or "water loving" and can cause corrosion in the fuel system and possibly in the combustion chamber. Phase seperation is another problem. Over time ethanol/gasoline fuels can phase seperate because water is more soluble in ethanol than gasoline. You get two liquid phases with the water/ethanol phase at the bottom of your tank because it is more dense than gasoline and you will lose octane! This is probably not that big of an issue IF you fill your tank often. But if it sits idle for long periods it is a huge issue. It is a big big problem for marine engines however. I much prefer MTBE!
Internal corrosion is the number one enemy for your engine. If the valve stems corrode they could break off and fall into the cylinder and ruin your engine!
Last month I drove from Nashville to Baltimore towing about 2800# all interstate and got about 12mpg. I've noticed mpg overall a lot worse than when I first bought the truck (9/2006). Used to get over 100miles on the 1st quarter-tank, now can't beat 85.
I always wonder at guys with the larger Fords but the same weak (IMHO) 5.4l engine...if the truck meets their expectations, etc.
Have an '04 F-150 Lariat Crewcab with 3.73 gears. Running empty, nothing in tow, and staying at the speed limit, I can crowd 20 mpg highway. City driving I hover around 14 mpg.
Towing, depending on the trailer and weight, varies between 11 and 13.5 highway. Using a higher octane in hilly country does help on the mpg.
Winter city driving is a killer. I'm lucky to see 10 mpg. I was in MN in January when it was seriously cold, like -3 for the high, and still got the same city mpg.
All and all, I'm happy with it.
on
1 Post
Originally Posted by JCA433
I get about 16.7 MPG with MTBE blend without towing.
http://www.startron.com/stretch.php?sec=4
http://www.jamestowndistributors.com...ct.do?pid=6412
