surging prob.
Old 02-05-2008, 08:43 PM
Razec's Avatar
Razec
Razec is offline
surging prob.
hello everyone im Cezar..
first let me say this is a great site, lots of info.
well i got a 97 7.3 f250 with a 40/70 hp. chip with 250, rounds on the clock. just recently had the tranny overhauled. tha day after i picked it up went to start it and just started surging at start up. WHOOP,WHOOP,WHOOP, after about 5 seconds or i accelerate it,, it clears right up, i shut it off and start it again does it everytime.
anybody got any ideas? this is my second diesel. im still sorta new to this
Old 02-05-2008, 08:50 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
does it even after the motor is hot?
Old 02-05-2008, 08:54 PM
Razec's Avatar
Razec
Razec is offline
yeah even after the motor is hot. any time i start it. some times i'll put it in neutral and it dont do it, thats whats got me confused..
Old 02-05-2008, 09:17 PM
c00nhunterjoe
alot of guys have had good luck with transmission range sensors, but before you do try unplugging the icp sensor to see if she quits the lope. the neutral part has me leaning towards the trans sensor though
Old 02-05-2008, 09:43 PM
Razec's Avatar
Razec
Razec is offline
help me out whats the icp sensor? i proly know just dont know the abbreviations.
Old 02-06-2008, 09:34 AM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
yep Joe is right on. TRS is probably your problem. It may not be adjusted or it may be bad.
here is the ICP sensor
Old 02-06-2008, 05:51 PM
Razec's Avatar
Razec
Razec is offline
thanks guys i'll try the icp. is the TRS located inside the transmission pan, or is it an outside sensor?
Old 02-06-2008, 06:01 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
No the TRS is on the outside of the trans where the shifter lever is one the drivers side of the trans. To remove it requires removing one nut, 2 bolts and an electrical connector
Old 02-06-2008, 06:11 PM
Action4478's Avatar
Action4478
Action4478 is offline
Tim ... how did you get a pic of my motor?...
Old 02-06-2008, 06:12 PM
Razec's Avatar
Razec
Razec is offline
Hello... yeah i just figured it out what it is duh.. sorry i sound so dumb im really not i promise, just not used to all the abbreveation lingo.
Old 02-06-2008, 06:19 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Rick if you look closely you will notice the allen head broken off in the HPOP fill plug. I assure you that is not your engine. Give me one good warm day and some hot water and your engine compartment will look like mine!! I'll make you a deal. I will detail your truck inside and out and you fix my missing paint and dent in my door!! lol Good deal huh?? FOR ME!!
Old 02-06-2008, 06:21 PM
MADVAN's Avatar
MADVAN
MADVAN is offline
I ask the same.
Waaaay to clean
Tim
I will give you my van for as long as you need it.
LLIB
Old 02-06-2008, 06:23 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Originally Posted by MADVAN
I ask the same.
Waaaay to clean
LLIB
Bill you can't even SEE your HPOP reservior let alone clean it!! Man I hate vans!!
Old 02-06-2008, 06:24 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
I ask the same.
Waaaay to clean
Tim
LLIB
I would turn you down cold but it is a Quigley!!!
Old 02-06-2008, 06:34 PM
c00nhunterjoe
quigly's are 4x4's arent they?
Quick Reply: surging prob.
