ngs and oil pressure
playing with th ngs today and i think my pump is dying a slow death. at 1\4 throttle i am maxing my ipr to keep up with icp levels, my peak icp reading is only 2500 psi and under full throttle it drops slowly, this is with a superchip only, no other c00nhunterjoe mods in place. tomarrow i hope to install my 14.7 and my 22k to see if it drops even faster. i suspect it will since it falls on its face with the 22k.
more to come........
i dont have 1500 bucks for a performance pump. the truck itself runs great even with my 14.7k mod in place, its only when i install the 22k that i have issues but i just had a feeling the pump is on its last leg so i figured its time to check it out.
as for which pump i want....i want the new one that you dont have to relocate the fuel filter for our trucks. i dont recall which one it is but its one of the 2 newest ones coming out that is a literal direct bolt on to all 7.3's with no mods to your truck. 1500 smackers though..ouch. if i can get away with a 17* pump i robably will when the time comes as long as it can handle bigger injectors without a problem but for the tme being i am letting it ride
got more numbers tonight, installed the 22k, the ipr adjusted to get the "desired" icp, held a max of "2500" psi and ipr duty cycle is 43% to accomplish this instead of 34% without the resistor. contrary to my theory the icp didnt drop off when the truck fell on its face, it held steady. so now i beleive i have a fuel pressure problem but had no time to investigate it tonight. i will have to get a gauge on it and drive it some more to see if my fuel pressure is dropping off withthe increased demands. a likely suspect for 236k on the origonal pump.
any other ideas?
a recap on symptoms. with 22k resistor in icp my way the truck starts off incredible hard, black smoke bellowing hardcore, then truck just falls on its face and starts to miss, no more smoke to speak of, can hold it to the floor while missing, never gets worse stays consistant. as soon as you let off it runs fine, no recovery time to get power back.
any other ideas?
