HPX question
Old 01-27-2008, 09:39 PM
blake 7.3L's Avatar
blake 7.3L
blake 7.3L is offline
Mine came from Dale great guy and great product! Install was quick and easy. Instructions were great!
Old 01-27-2008, 09:43 PM
Robbgt's Avatar
Robbgt
Robbgt is offline
Was it braded or solid line? If he had the solid I would have purchased it from him instead...
-Robb
Old 01-28-2008, 07:52 AM
blake 7.3L's Avatar
blake 7.3L
It was braded but so are the stock feed lines so it does not really worry me. The stock line have lasted ten years now. What is the advanage of the solid line?
Old 01-28-2008, 01:59 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Lightbulb
Mine is also from Tymar, and he has stated that the best place to connect the HPX is in the last plugs in the rails but in the drivers side is impossible, so you have to choose the next one, and when you move the stock line from there, the stock connector is 90*, and the new one for that line is straigth, so there are less friction and better flew of the oil and that is better in teory. For that reason and been agree with what blake 7.3L wrote, I choose Tymar line instead the solid line.
Old 01-29-2008, 09:08 AM
BEECHBM69's Avatar
BEECHBM69
BEECHBM69 is offline
I read sometime back when the solid ones first came out that there were some concerns with metal fatigue due to vibration. Do we have any higher mileage betas that can confirm or dispel this?
Dan
Old 01-29-2008, 11:06 AM
scatgo's Avatar
scatgo
scatgo is offline
I can see that happening. And over time the hot cold cycle might lossen things up and cause leaks with the soild pipe because of exspansion and contraction. A hose would flex and stand up better.
Old 01-29-2008, 02:15 PM
1969fordguy's Avatar
1969fordguy
1969fordguy is offline
So what kind of change are you guys seeing after doing this mod? Is it really quieter? Smoother idle? More torque? (alright I made the last one up...)
Old 01-29-2008, 02:19 PM
blake 7.3L's Avatar
blake 7.3L
Yes quieter, smoother idle, more throtle respose. Well worth the $34!
Old 01-29-2008, 03:14 PM
heathrunkles's Avatar
heathrunkles
heathrunkles is offline
A lot smoother idle and also a tad "quieter"(not sure if you can link that word with these engines)
Old 01-29-2008, 03:20 PM
helifixer's Avatar
helifixer
helifixer is offline
Received 3,697 Likes on 1,136 Posts
why better for to hear the 4" strait exhaust with.
Old 01-29-2008, 03:23 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
HPX MODE.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o> </o>
This hose is used to bridge the 2 high pressure oil rails in the heads that feed the injectors on the 7.3L Powerstroke.
The installation of this hose will typically smooth out rough idles as the ICP can now sense the pressure in both heads, quiet the engine, as well as provide improved oil flow to the injectors.<o></o>
<o> </o>
This kit is intended for installation on a power stroke engine to ensure that the high-pressure oil rails receive the same amount of high-pressure oil from the high-pressure oil pump. The result of installing this kit includes, but is not limited to, a quieter running engine, smoother idle, and more responsive throttle. This kit is recommended to all power stroke owners from model year 1994 through and including the 2002 model year. <o></o>
This kit will NOT eliminate what is commonly called “cackle” or “idle knock”. One side effect of this kit after installation is that the engine runs quieter. This allows you to hear other potential problems in your engine that were previously covered up by engine noise.<o></o>
Old 01-29-2008, 03:37 PM
bkcowboss's Avatar
bkcowboss
bkcowboss is offline
is it a typo that they did not include recomendations for 03 (and some special order 04) 7.3l PSD's
Byrd.Dog
03-25-2015 07:31 PM
Byrd.Dog
11-19-2014 12:37 AM
Byrd.Dog
08-30-2010 09:35 PM
Byrddog
48
04-16-2009 07:51 AM
Byrddog
01-13-2005 06:22 PM
Quick Reply: HPX question
