3' or 4' cb antenna
Old 01-12-2008, 07:58 PM
wmiller's Avatar
wmiller
wmiller is offline
3' or 4' cb antenna
just bought a cb adn need antenna. Which length looks best on these trucks. Haven't decided yet if i want to mount on mirrors or in bed
Old 01-12-2008, 09:05 PM
barebackjake's Avatar
barebackjake
barebackjake is offline
i run the 5' wilson 1000 on the top of the cab works awesome
Old 01-12-2008, 09:19 PM
wmiller's Avatar
wmiller
wmiller is offline
i'de rather not have it on the roof as i worry about catching it on sheds and trees
Old 01-12-2008, 09:22 PM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
Maybe you should consider a bumper mounted set up.
Old 01-13-2008, 08:26 AM
barebackjake
a bit of dynamat ya dont even notice it whakin the trees, birds, drive through overhangs.....
you would get a better ground plane mounted in the bed and could get it a bit lower too
Old 01-13-2008, 10:01 AM
Talyn's Avatar
Talyn
Talyn is offline
Roof mounted antenna's are the best if possible.
Otherwise you loose signal. Mounting on the roof allows the truck help gather signal. if you mount on bumper or mirrior, you will always recieve better on one side then the other, yada yada.
I have a little wil. I like it, but dont use it anymore. Going k40 next antenna/system.
Go look up a firestick, they are about 2' long and you can run linears though them if you want.
Also, remember to go get your antenna modulated to your CB, otherwise you will blow out your finals.
The only way around this is to buy an antenna like a k40 which does not require modulation to the CB.
If your not sure what i'm talking about. I'll slightly explain it.
There is a wire inside the antenna, they basically cut it to lenght to match it up to the cb. If the wire is to long or to short, you basically f up your cb.
Old 01-13-2008, 11:13 AM
caseydudem's Avatar
caseydudem
caseydudem is offline
Anyone know where you can get an antenna this size for your am/fm radio? I would like a nice one for the stereo.
Old 01-13-2008, 11:14 AM
fordman837000's Avatar
fordman837000
fordman837000 is offline
i run a 9' whip use to be off the bumper in the back now its mounted through the bed on the pass side where I had a small rust spot starting. I also run a 300 watt heater shhhh! It screams now!
Old 01-13-2008, 11:20 AM
cookie88's Avatar
cookie88
cookie88 is offline
If you want to run duals for more than just looks mount them as far apart as you can. That means the mirrors, but a bed mount can be made to work.
You don't need to pay somebody to "modulate" your antenna. SWR meters are not expensive and not difficult to use. Just remember never key the mic without an antenna installed.
Old 01-13-2008, 12:41 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Scott what happens if you key the mic with no antenna's? Also I am very iliterate to CB workings. I have a CB and need new antenna's. Right now they are mounted to the tool box in the bed. Both are hooked up. I have heard that at times 1 is better than two. Can you run the second as a dummy with out issue? Also what do you do when you modulate your antenna's? Anybody have a link or something like CB's for dummyies?
Old 01-13-2008, 02:08 PM
IceboxFX's Avatar
IceboxFX
IceboxFX is offline
those are Wilson 4 foots mounted on the mirrors, I have them behind the cab now but I don't have any pics of that.
Old 01-13-2008, 04:29 PM
wmiller's Avatar
wmiller
wmiller is offline
I have a cobra 19 ultra 3. If i but antennas on the mirrors or in the bed what do i need to do to make it work?
Old 01-13-2008, 05:05 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
you can get the dual antenna wires, i have them for my firestix. that would be it, if you mount to aluminum a ground strap is also needed to optimize performance.
if you key a mic without an antenna you risk burning up your crystals. not guranteed but risky.
and where might one get one of these 300 watt boosters?
Old 01-13-2008, 05:18 PM
IDMooseMan's Avatar
IDMooseMan
Originally Posted by c00nhunterjoe
...and where might one get one of these 300 watt boosters?
Yes, inquiring minds want to know.
Old 01-13-2008, 06:09 PM
IceboxFX's Avatar
IceboxFX
IceboxFX is offline
i used these to mount them in my bed.
http://cgi.ebay.com/PAIR-3-WAY-ALUMI...QQcmdZViewItem
and something like this when they were on my mirrors-
http://cgi.ebay.com/ProComm-JBC436-6...QQcmdZViewItem
you will also need a "t" connector, you can get these at radio shack
http://cgi.ebay.com/T-Type-UHF-Coax-...QQcmdZViewItem
and coax cable.
Quick Reply: 3' or 4' cb antenna
