Flip screen / CD player in 81 F100
Is the flip screen deck the same size as a regular deck? If so just get the center peice ou of a 85 or 86, With mine I had to cut this piece back to the molding and add another piece of plastic behinde. I then added a brace in behinde to support the deck. Just look in my gallery
Edit with the way I did mine both the alpine DIN size 1 and DIN 2 would fit. DIN 2 would just have a little less plastic around it
The problem with your 81 is the size of the hole in the trim panel its meant to fit the old radio with the ***** off to the sides(to tall and narrow to fit regular deck). If your installing the DIN 2 sterio you might only have to widen the hole
We need some more info like wich deck you want and wich radio is in it now?
budsweeds
10-01-2014 12:29 PM
billkean
11-12-2005 12:49 AM
