i have the following error codes
0113 iat sensor 1 circuit high input
1282 injector pressure control excessive
0344 camshaft position sensor a bank 1 ckt intermittent
1212 inj cntrl press lower than expexted
could my cam sensor be causing all of these?? where should i start to fixing this?
it runs good once it's warmed up kinda weak when cold but i have been told it's normal no i haven't cleared codes the car part store wouldn't do it can you unhook batterys and clear them like old trucks
I really don't know ,, I have never tried It ...I have a scanner that can clear them.....
What is the motor doing? no start? start then dies? give us your symptoms
the only thing i can notice is the cel light only comes on when truck is cold and when it does come on the idle changes kinda lopes i can drive a mile or two down the road put it in neutral kill it then restart a few seconds later and no cel and runs better
