error codes
Old Dec 2, 2007 | 11:01 AM
arkredneck's Avatar
arkredneck
error codes
i have the following error codes
0113 iat sensor 1 circuit high input
1282 injector pressure control excessive
0344 camshaft position sensor a bank 1 ckt intermittent
1212 inj cntrl press lower than expexted
could my cam sensor be causing all of these?? where should i start to fixing this?
Old Dec 2, 2007 | 01:33 PM
Action4478's Avatar
Action4478
How is it running? long crank can set CPS code
1211 & 1212 can be there for a few reasons ,,
Need more info..
Are you chipped ?...
Old Dec 2, 2007 | 06:24 PM
arkredneck's Avatar
arkredneck
no chip no 10k mod only thing done is a downpipe and 6637 mod and fpr shimmed it only cranks for a while when it's cold
Old Dec 3, 2007 | 05:21 PM
arkredneck's Avatar
arkredneck
anyone got any ideas on how to fix this?
Old Dec 3, 2007 | 05:29 PM
tjbeggs's Avatar
tjbeggs
What is the motor doing? no start? start then dies? give us your symptoms
Old Dec 3, 2007 | 05:30 PM
Action4478's Avatar
Action4478
Does it run OK ?
..It could be an old code,,
Did you clear them & see if they come back?...
Old Dec 3, 2007 | 08:14 PM
arkredneck's Avatar
arkredneck
it runs good once it's warmed up kinda weak when cold but i have been told it's normal no i haven't cleared codes the car part store wouldn't do it can you unhook batterys and clear them like old trucks
Old Dec 3, 2007 | 08:26 PM
Action4478's Avatar
Action4478
I really don't know ,, I have never tried It ...I have a scanner that can clear them.....
Old Dec 3, 2007 | 08:29 PM
arkredneck's Avatar
arkredneck
the only thing i can notice is the cel light only comes on when truck is cold and when it does come on the idle changes kinda lopes i can drive a mile or two down the road put it in neutral kill it then restart a few seconds later and no cel and runs better
