Rear Axle Tag question
guys I was under my truck today and found the rear axle tag and I think I have it mostly sorted out but don't really understand how the tag works.
top line 410 D8TA SB
bottom line 603901-4 LS
Door tag confirms
built in Kansas
8400lb GVWR
3800lb Front Dana 44
5300lb rear Dana 60 with 4.10's and Limited Slip
Here is my Vin X26SKEA2179
WB = 155
Color = S
Type = X262
Body = dbm
trans = K
Axle = B4
DSO = 21 ???
what is the rest of the tag telling me? thanks for the help.
Door tag confirms
built in Kansas
8400lb GVWR
WB = 155
Color = S
Type = X262
Body = dbm
trans = K
Axle = B4
DSO = 21 ???
Originally Posted by rockdawg84
guys I was under my truck today and found the rear axle tag and I think I have it mostly sorted out but don't really understand how the tag works./ top line 410 D8TA SB / bottom line 603901-4 LS SEE AXLE CODE B4 ~ Same Info.
Door tag confirms
built in Kansas
8400lb GVWR
WB = 155 Color = S Type = X262 Body = dbm trans = K Axle = B4 DSO 21 ??
Door tag confirms
built in Kansas
8400lb GVWR
X26 = F250 Super Cab 4WD
S = 400 2V
K = Kansas City Assembly Plant
EA2179 = `1979
155" Wheelbase
S = Brite Dark Blue Metallic
X262 = F250 4WD Super Cab / 8400 lbs. GVWR
DBM: DB = Blue all Vinyl / M = Styleside Pickup
K = C6 Cruiseomatic
B4 = Dana 60 / 4.10-1 / Limited Slip / 5300 lb. Rear Axle Capacity
DSO 21 = Atlanta GA Ford District Sales Zone (where dealer ordered truck from)
69 F100 LWB
04-10-2007 03:03 PM
