G2 Axle Code; Dana 60 or 70?
Old Apr 10, 2007 | 07:06 AM
69 F100 LWB's Avatar
69 F100 LWB
I know, another axle code question... I'm sorry!!!
My 84 F250 has an axle code of G2 and the tag on the axle says 4:10. I have searched everywhere and can't determine exactly what it is.
I can't figure out is if it is a Dana 60 or 70 or if it is limited slip.
I looked at the hub and it is flush with the wheel. However, this is a dually which I think was part of the Centurian conversion. So I don't know if there is an adapter between the inner wheel and the axle mounting pad that is moving the wheel out board making it look like it is flush with the hub.
Lastly, the axle tag says 4:10, not 4L10 or 4 10 (the colon is actually stamped on the tag between the 4 and 10). And the letters LS are at the end of the bottom line.
What I've found by searching is a Dana 70 4:10 limited slip, but I don't have a "warm and fuzzy" that I've researched correctly.
Any help would be appreciated!!
Old Apr 10, 2007 | 01:04 PM
Franklin2's Avatar
Franklin2
Jack both rear wheels up off the ground, and leave it in park. Grab and turn one wheel. If the other wheel freely turns in the opposite direction, it's not limited slip.
Old Apr 10, 2007 | 01:29 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
G2 = Dana 70 / 4.10-1 / Locking / 6300lb axle capacity
Source: 1980/89 Ford Light Truck Parts Catalog~Section 40, Page 6~1980/89 Rear Axle Warranty Plate Code Chart
Since this is the exact same parts catalog the Ford Dealers use, I assume you didn't search there.
Old Apr 10, 2007 | 02:42 PM
69 F100 LWB
Thanks for the info!!!
Is the parts catalog available online? My local dealership isn't very helpful and I emailed my other Ford parts guys, but they haven't got back to me yet. I do try to search as much as possible before I post. Shoot last night I even crawled under the truck and cleaned off the tag and pulled the wheel cover off to try to figure out what it was.
Thanks again for the info!!
Old Apr 10, 2007 | 03:03 PM
NumberDummy
Is the parts catalog available online? My local dealership isn't very helpful and I emailed my other Ford parts guys, but they haven't got back to me yet. I do try to search as much as possible before I post. Shoot last night I even crawled under the truck and cleaned off the tag and pulled the wheel cover off to try to figure out what it was. Thanks again for the info!!
Not sure about whether the catalogs are available online..that wouldn't be a bad idea. An explanation to how to use one and what all the symbols refer to would be needed, tho.
Your comments about the local dealer are true nationwide. Passion has gone, the want of a paycheck is the only reason most of the totally clueless help is there today. If Ford wants to reach a profitable level again, the dealers is where they should start first. The dealers and their scheiss additude is what has gotten Ford in the hole. Ppl are feed up, and are buying other vehicles. I can't say I blame them, either.
GasserGary
Oct 19, 2016 05:23 AM
78 Ford F150 460
24
Aug 15, 2016 03:52 PM
squirrelmaster
1978 - 1996 Big Bronco
May 15, 2016 03:48 PM
Norton72
Offroad & 4x4
16
Jul 12, 2012 05:28 AM
Galaxie427
May 11, 2004 07:21 PM
