Fuel guage off and on
Old 11-06-2007, 06:21 PM
Bookman's Avatar
Bookman
Bookman is offline
I've cleaned the contacts at the sending unit on the inside tank but still having the guage working when it feels like it. I there a way to narrow it down to the guage switch under the dash or the contact on the board at the dash guages?
The guage has never read full only 3/4 at best but it used to at least always read. Now it is mostly reading on empty!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-06-2007, 07:01 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Hole in float ?
Ground connection on SU secure ?
ICVR functioning with correct pulse of power ?
Contacts on Printed circuit clean ( Not corroded ) ?
ICVR ground tab secure ?
Old 11-06-2007, 11:01 PM
sleep_deprived129's Avatar
sleep_deprived129
sleep_deprived129 is offline
Make sure your ground wire is hooked up good
Old 11-07-2007, 03:22 AM
Bookman's Avatar
Bookman
Bookman is offline
The ground at the sending unit is good. What is ICVR? How do you chase the lead from the switch from tthe guage to the display circuit?
Old 11-07-2007, 11:00 AM
bertha66's Avatar
bertha66
bertha66 is offline
Sounds like the constant voltage regulator, not sure where it is on the 67 and newer trucks, but on my 66 it was on the back side on the dash.
Old 11-07-2007, 12:52 PM
blue68f100's Avatar
blue68f100
blue68f100 is offline
The ICVR is attached to the instrument panel on my 68. If all other gages are fine, I would lean to ward a bad connection or sending unit. There is a bullet connector under the dash, this is where the wires that come from the sending unit, dome light connect to the main harness. I would twist these connection to make sure you have a good connection. Connect a volt meter on the sending unit and see if it's constant or jumping around. If you have a 100ohm (3-90) variable resister ( or 50 fixed), connect it where the sending unit is. This can be used to test the sending unit.
To trace the leads , notice the color and trace on the wire. It will come out under the dash on the kick panel, high through a plastic garment. The wire is routed over the door frame. At the tank it is ground to the cab, make sure that screw connection is clean and tight.
Old 11-07-2007, 06:58 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
ICVR is the Instrument cluster voltage regulator.
It is pulsing power of 5 volts not constantpower
Old 11-07-2007, 08:09 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C6DZ-10804-A (1967/70); D1AZ-10804-A (1971/72) .. ICVR (Constant Voltage Regulator) Bad ICVR, the gauges do the hula, fluctuating back and forth.
C0AZ-9202-B .. Fuel Sender Float ~ The float is made from two pieces of copper soldered together, solder breaks down, gas seeps in, float slowly sinks to the bottom of the tank.
C1TF-9276-A .. In Cab Tank Fuel Sender Gasket
D7TZ-9275-G .. In Cab Tank Fuel Sender (comes with float & gasket)
The float, sender and gasket are still available From Ford
Everything except the fuel sender is available from NAPA.
NAPA can cross these Ford part numbers over to the brand they sell.
Old 11-08-2007, 10:23 AM
Bookman's Avatar
Bookman
Bookman is offline
Thanks guys this will be a lot of help.
cheddar89
02-14-2012 08:54 PM
kamloops
1997 - 2003 F150
04-26-2008 11:35 AM
Scrapiron66
10-04-2006 12:34 AM
priv8pilot
07-20-2006 10:36 AM
JoeBlow
17
11-04-2005 04:33 PM
Quick Reply: Fuel guage off and on
