Hydraulic Line to Slave Cylinder..WTF?!?
Old 11-06-2007, 09:52 AM
93tankus's Avatar
93tankus
93tankus is offline
Hello all,
This past weekend, i was able to finally replace a leaking slave cylinder in my '93 F150. It was so nice of FoMoCo to conveniently place inside the bell housing....but i digress...
Anyway, after getting everything back in order, I went to attach the hydraulic line into the new slave cylinder. But what's this?!?!? It won't fit!!! Aaargh!! It was close, but it seemed like the new slave cylinder had a tapered-down reciever, while the hydraulic line had a flat end to it. A trip to Auto Value with the old hydraulic line confirmed this difference. Siiigh.
So, I had to order a new master cylinder/hydraulic line, as the original master cylinder in the truck would not allow the hydraulic line to be disconnected. Aaargh. Another $100+ for parts that work perfectly fine.
Anyway, aside from the rant (sorry!!), has anybody else run into this issue?? Did I miss something from the beginning??
I'm just thrilled to finally replace this leaky slave cylinder. I also put in a new clutch and rear seal while I was in there. So, all was not lost!!
Thanks
Old 11-06-2007, 09:55 AM
quicklook2's Avatar
quicklook2
quicklook2 is offline
good idea to look at the new parts so they match the old parts.
Old 11-06-2007, 10:27 AM
93tankus's Avatar
93tankus
93tankus is offline
thank you soooo much for the incredible insight...
Old 11-06-2007, 10:41 AM
quicklook2's Avatar
quicklook2
you are soooo welcome and i hope it helps you in the future.
i was really posting it for others, as you have already learned your lesson.
Old 11-06-2007, 01:17 PM
andym's Avatar
andym
andym is offline
How would he be able to compare the end of the old hydraulic line to the new slave cylinder until he has it all apart?
That sucks you had to go through that, and I don't know what "Auto Value" is, but it sounds like a discount parts store. You get what you pay for. Personally, I would have paid for a new Ford part, as the old one you had lasted 14 years. I wouldn't count on a discount part lasting more than a year.
Old 11-06-2007, 01:24 PM
quicklook2's Avatar
quicklook2
i meant to check the old slave cylinder end to the new slave cylinder end.
Old 11-06-2007, 02:46 PM
blinkjs's Avatar
blinkjs
blinkjs is offline
I just replaced mine last year in my 94' with an OEM slave cylinder from Ford and had zero problems everything fit well. That line is a pain in the a$$ to get in and out though.
Old 11-06-2007, 03:18 PM
ghunt's Avatar
ghunt
ghunt is offline
I'm buying a '94 that the owner told me he had to replace the clutch master & slave cylinder on a few years ago- told me he took it to a shop and they told him they had to replace everything, couldn't just replace one component.
Maybe this is why?
The truck also has a super stiff clutch pedal which I will be looking into fixing...
Broncoslocos
04-08-2015 12:20 PM
jnduke33
08-18-2014 08:41 PM
jkschneider
21
01-25-2013 12:42 AM
1994F2507.3L
05-10-2012 04:49 PM
bigfish6025
17
09-09-2011 09:32 PM
Quick Reply: Hydraulic Line to Slave Cylinder..WTF?!?
