HPOP questions.
HPOP questions.
I'm trying to figure out if my HPOP is weak. My truck starts good when its cold and runs good as long as you don't shut it off. Once the engine is warm the truck won't start. I put a pressure gauge on the cylinder head today and got these readings. When first started and at idle the pressure was at 1200psi. That pressure dropped to about 700psi at a idle warm. When trying to start warm the pressure was at only 200-250psi. Are these numbers right? The warm pressures seam low to me and make me wonder if the HPOP is gone.
on
IPR O-Ring Kit (for when IPR valve replacement is not required)
(Ford) F6TZ-9C977-AN (F6TZ-9C977-AA?)
(International) 1825806C92 (1825806C91?)
procedure
http://cw-diesel.com/LuxSite/IPRInfo.htm
procedure
Finally got some time to work on the truck this week. I pulled the IPR and sure enough the two small o-rings on the end of the IPR were dried out and there were chunks of them missing. I cleaned it up like the link that was posted showed to and put it back together. Truck starts fine now. Thanks for all the help. The best part is with my company's discount at International the o-ring kit came to $20 bucks.
Thanks,
David.
Thanks,
David.
I too changed my HPOP right after purchasing my truck. Same symtoms, hard start after it was warm. I knew very very little about our powerstroke engines so I carried it to the stealership. They told me the pump was bad, cavitating, causing the oil to foam, which resulted in the hard warm starts. I did not have them change it, did it myself, which did cure the problem. But, the pump came with a new IPR and seals.
Now I am thinking ........... u know
Them Stealership *****ers
