Affordable Gauges (EGT/Boost)???????
I am looking for a reasonable priced, and easy to install piro gauge preferably with a boost gauge as well... I don't care if they are both on the same gauge or 2 seperates... Can someone recommend a "POD" design with gauges that is not going to break the bank?
Look at these, http://www.dieselmanor.com/gauges/gauge_kits_psd.aspEasy to install and matches well.
Originally Posted by firemediceric
Can you point me to a link?
I think all I want is a cheap tranny gauge, but I could probably be talked into more.
http://cgi.ebay.com/ebaymotors/SPW-O...spagenameZWD1V
Thanks for the link.
Hopefully the probe will fit in the tiny test port.
What gauge wire do you suggest I run? I would imagine that 18 gauge would be heavy enough.
Any suggestions on what to use as a bracket to just allow it to hang from the underside of the dash?
I ran #12 wire, but i am a liitle nuts. 16 would be minimal for me.
But if you don't want to cut into your dash:
http://dieselmanor.com/pillars_pods/..._universal.asp
