Affordable Gauges (EGT/Boost)???????
Old 11-08-2007, 09:26 AM
fordzilla01's Avatar
fordzilla01
fordzilla01 is offline
I am looking for a reasonable priced, and easy to install piro gauge preferably with a boost gauge as well... I don't care if they are both on the same gauge or 2 seperates... Can someone recommend a "POD" design with gauges that is not going to break the bank?
Old 11-08-2007, 09:35 AM
03_PSD's Avatar
03_PSD
03_PSD is offline
look on ebay for glowshift, they are pretty cheap, but don't know how good they are. someone will chim in with better ideas. also look at some of our sponsors sites they carry tons of different types.
Old 11-08-2007, 11:24 AM
empiretc's Avatar
empiretc
empiretc is offline
The prosport/spw/megan gauges on ebay are way better than glowshift- if you want blackout style gauges. Those are some of the best.
You can get a pillar mount pretty cheap from glowshift and put other gauges in it.
Old 11-08-2007, 11:29 AM
TN_F250's Avatar
TN_F250
TN_F250 is offline
I got the triple A-pillar pod with autometer pyro, trans and boost from egauges.com for 271 and change.
Old 11-08-2007, 11:40 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Look at these, http://www.dieselmanor.com/gauges/gauge_kits_psd.aspEasy to install and matches well.
Old 11-08-2007, 11:42 AM
firemediceric's Avatar
firemediceric
firemediceric is offline
I thought I had a steal the other day on a trans temp gauge. $9.99 at Advance Auto.
Went to install it and the probe would not fit into the test port of the trans.
Old 11-08-2007, 12:29 PM
empiretc's Avatar
empiretc
empiretc is offline
In installed the SPW pyro and tranny gauge in a custom mount for ~$100. Everything fit perfectly. I figured that would be enough, but gauges have been my pms lately.
the fuel and oil pressure will be going in within the next couple of weeks.
Old 11-08-2007, 04:51 PM
firemediceric
Can you point me to a link?
I think all I want is a cheap tranny gauge, but I could probably be talked into more.
Old 11-08-2007, 08:14 PM
empiretc's Avatar
empiretc
empiretc is offline
This is a very affordable and good quality gauge (they will take an even $30 total for it). I wish it said trans on it instead of just oil, but it works 100%. All you need to provide is the wire from the sending unit to the actual gauge.
http://cgi.ebay.com/ebaymotors/SPW-O...spagenameZWD1V
Old 11-09-2007, 08:32 AM
firemediceric
Thanks for the link.
Hopefully the probe will fit in the tiny test port.
What gauge wire do you suggest I run? I would imagine that 18 gauge would be heavy enough.
Any suggestions on what to use as a bracket to just allow it to hang from the underside of the dash?
Old 11-09-2007, 01:43 PM
empiretc's Avatar
empiretc
empiretc is offline
Probe fits perfect. Use some rtv and do not over tighten.
I ran #12 wire, but i am a liitle nuts. 16 would be minimal for me.
But if you don't want to cut into your dash:
http://dieselmanor.com/pillars_pods/..._universal.asp
cdiddy
01-04-2008 11:38 PM
pip-clark
16
09-07-2007 09:44 PM
FORDSDOWNER
1999 to 2016 Super Duty
08-27-2007 03:17 AM
Neal 97 250
61
07-21-2007 11:59 AM
sean23johnson
44
01-09-2007 10:54 PM
Quick Reply: Affordable Gauges (EGT/Boost)???????
