10 40 oil good for F150?
I'd just stick with the 5w30 oil regardless of mileage - but thats just me. Basically if tolerances or wear becomes enough of an issue with leaks, lack of compression whatever - its better to fix what needs to be fixed than mess with additives or different types or weights of oil. I don't think the 10w40 would give you any gains in longevity, mileage or anything else either at this point. Anyone else have opinions on this?
I personally wouldnt put any other grades than 5w20 or 5w30 in my truck. But i work for my countys fleet programs, and all our vehicles( somewhere around 200-300 f-150s, about 300 f-250 to f-350s, those are an est. of our vehicles.) use the same 15w40 oil, and we have never had any problems with this weight oil. If you have it, you can use it.
6 quarts should do it.. 10w40 is a little thick, but if the temperature where you live is above freezing, should not have troubles. if you have high milage and motor is using some oil, the thicker stuff might help a little. 40 wt is a little thick, but if you got a good supply, go for it.
10w40 is really too thick. The engine wear mostly happens at start-up and it is thicker cold and will take longer to reach the heads and increase wear. There are no cam bearings in the heads, just a thin layer of oil between the cam and head. 5W-xx will get the oil up there much faster.
You fill the differential until it starts to run back out of the plug.
It will work fine. It takes 6 qt's. Only use a Motorcraft filter too, they have the best anti-drainback valve to keep oil in the filter. It is common on alot of these trucks to show 1/2 qt. low after an oil change. For some reason, the dipsticks don't seem to go in far enough or something. Just leave it at 1/2 qt. low if that is what it shows and as long as it shows this later when you check it, you will know it is full.
Buy 7 quarts and keep one behind/under the seat. I have to add about a quart between oil changes. Don't know where it goes...just dissappears.
10-40 should be just fine. The previous owner of my truck used 10W40 since the day it rolled off the showroom floor, and I bought it at 80K and she runs like a champ with no noise at all. I have switched back to 5W30 just because our other vehicles use it too.
I wouldn't think 10w40 would be a problem. Heck my mechanic even uses 20w50 but I live in Phoenix, he maintains alot of lincoln tc's with well over 300K, no motor problems whatsoever.
On the other hand, if the manual says 5w30, may as well use it but if is you have 10XX whatever may as well make good use of it. Just my two cents.
Mike
Mike
Jnowaczyk
Modular V10 (6.8l)
04-20-2014 06:06 PM
