05 F150 4.2 is missing
Old 10-22-2007, 07:00 PM
willo71's Avatar
willo71
willo71 is offline
Question 05 F150 4.2 is missing
around 1200 to 2000 rpm my truck is missing. it is a 5 speed and has 40k. anyone else have these issues? what can i do to correct the problem. i am new to the forum and any suggestions would be appreciated. thanks!
Old 10-22-2007, 11:03 PM
BrianA's Avatar
BrianA
BrianA is offline
Hi and welcome to FTE! Glad to have you here.
Might be a little early with only 40 K miles, but first thing I'd try is new plug wires. But, being an '05, it could be pushing 3 years old and that seems about normal life.
Seems plugs and wires are two of the more common causes of an engine "miss".
That is unless it is a dead miss; like one cylinder not firing every time. But, if that was the case you'd likely get an OBD-II code and the Check Engine light would come on.
If you do decide to replace the wires, I suggest Motorcraft. (You can find them cheaper than from the dealer.)
Again, welcome and keep us posted.
Old 10-23-2007, 08:30 PM
willo71's Avatar
willo71
willo71 is offline
ok...drove my truck to work today. now the engine light has come on. havent replaced the plug wires yet. how do i check to see what the code is?
Old 10-23-2007, 09:12 PM
BrianA's Avatar
BrianA
BrianA is offline
You have to have access to an OBD II code reader.
(OnBoard Diagnostics - 2nd generation)
Try AutoZone or a local shop. Autozone will generally do it free of charge.
Come back with your code info and we'll try and help.
(I guess it's reasonable to expect a code indicating a miss on cylinder "X")
edit to add: It would not be unreasonable to at least check to make sure all the plug wires are secure at both ends: on the plugs good and tight, and secure in their coil pack sockets on the other end. You might get lucky!
Old 10-25-2007, 10:07 PM
willo71's Avatar
willo71
willo71 is offline
Smile
hey. had it checkout at the dealer and they put a new coil and plugs in it. seems to be running well now. thanks for the help!
DBANDGB
07-15-2014 04:46 PM
tractors55033
1983 - 2012 Ranger & B-Series
10-13-2009 05:57 PM
n8sv10
Modular V10 (6.8l)
09-26-2008 02:01 PM
CMWINTER
1997 - 2003 F150
05-29-2003 07:29 AM
amsnss
04-17-2002 09:28 AM
Quick Reply: 05 F150 4.2 is missing
