water leaking thru top of rear window!!
Old 11-28-2013, 07:40 AM
JOE SKI's Avatar
JOE SKI
JOE SKI is offline
Mine also leaked where the glass attaches to the plastic frame so I sealed that also with stuff from Napa. My plastic frame was cracked so I glued it with super glue and then used the butyl tape and no leaks.
  #32
Old 11-28-2013, 07:53 PM
Timo2's Avatar
Timo2
Timo2 is offline
Silicone is not advised for this problem. Acetic acid released during cure will initiate and accelerate corrosion.
I used white silicone-free DAP sealant on a cheap used 01 truck, applied to the trim from the outside, without removal of anything. Cost, 3 bucks, time, less than 5 minutes. Perhaps not permanent, but whaddya want for a $500 truck? It doesn't leak now, and it matches the color.
  #33
Old 11-28-2013, 09:19 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
The plastic trim is not connected to the window. I also caulked the crack of a truck several years ago. Helped quite a bit.. couple years later i removed the window and resealed it to the cab steel wall. That is where the butyl strip seals... the trim on the outside is just window dressing, does nothing.... but filling the crack might keep out 90% of the leaks.
  #34
Old 11-28-2013, 09:41 PM
Timo2's Avatar
Timo2
Timo2 is offline
Think like a water drop...that plastic, when sealed to the cab prevents most rain water from contacting the failed factory glass seal. Window dressing repurposed, sans silicone. My leak seemed to come from the top edge of the glass, and although rain can still contact the sliding window, it no longer rains inside on the top off the back seat back.
  #35
Old 11-30-2013, 03:25 PM
ecdams's Avatar
ecdams
ecdams is offline
My '97 leaked like a convertible with the top down if you were sitting in the back seat on the passenger side (super cab). I fixed it by using clear silicone caulk all along the top seal.
  #36
Old 02-19-2024, 12:26 PM
F150 T ruck's Avatar
F150 T ruck
F150 T ruck is offline
2nd Gear
It may not be a problem now, but wait until it gets mold, or mildew in your upholstery from the moisture.
  #37
Old 02-19-2024, 12:39 PM
F150 T ruck
2nd Gear
Hopefully you don't end up with any mold. or mildew in your upholstery from the moisture.
Airborne-F250
06-03-2017 12:18 AM
Larry Garland
1947 and Older Ford Trucks
06-01-2016 07:44 AM
716F150
2009 - 2014 F150
05-19-2016 08:09 PM
notthemaniusedtobe
26
04-02-2015 02:07 PM
DirtyCustoms
13
04-21-2012 07:36 AM
Quick Reply: water leaking thru top of rear window!!
