Bread Truck 53
Bread Truck 53
Does anybody here know anybody who owns truck like mine? It can be seen at: www.purple53.com
I'm trying to find replacement door seals and I'm not having any luck so I'd like to find another owner. My truck had 9 hinged doors, 7 on te back side. The seals need to be replaced. I'd be willing to PAY someone money if they help me locate replacement door seals.
You need to think outside the box, (pun intended) . I would not look for door seal per se for the bread box, but rather a profile as in an extruded rubber seal that is made and sold by the foot for many applications. Many of the OEM's buy this way and then glue to their own manufactured door,windows,vents,drawer openings and tool boxes,utility bed doors and hundreds of other uses. The profiles are made in many common shapes and sizes in a few different durometer ratings (hardness ) the most common and usable being 60-70 D on a shore a scale. The duro is "before extruding" into a sponge shape. The end product is normally measured as "rate of compression" so some have more give than others. Most will make it around the corners and then you can join at the lower edge of the door or opening. I would start with getting some shape ideas first and then request samples of product from the manufacturer. There are many extruders of the sponge form of this and cater to different markets. I would start with www.steelerubber.com they have online samples and the streetrodders go there first. If this words out you can send the bread (finders fee) to Jon, King of worthless trivia and knowledge. Just joking, but I hope this helps you. Steele sells the lower quantities but there are many other that I have sold for in the past Greene Rubber is a good one, but keep in mind that I was buying in thousand foot rolls to resell to the Aerospace and Industrial trades. However try this link for a handful of choices http://www.extrudedrubber.com/ , maybe there is one closer to you or has something Steele does not.
Jon
Jon
Originally Posted by akissz
Hahahaha
Do you have any better ideas?
Originally Posted by 55paneltrk.
Maybe if you strap on a purse and put on a pair of those dandy red shoes, then click your heels together 3 times, all your dreams will come true.
seems like just another kook trying to solicit money.
First, there is a lot of joking around on this board but everyone is more than happy to offer help. There a lot of helpful and knowledgable people here. A lot of the members have trucks that need parts that you just can't pick off the shelf at the local parts store and over the years we have found parts not necessarily intended for use on our trucks but work for us. Some of these ideas seem really off the wall but really work. The advice that CIAF supplied was sincere and helpful. All the guys here are willing to help all new comers, no matter how many times the same questions are asked. Please show some respect by not being a smart a** in one of your first posts.
As for the grove in the door, maybe it's a big enough grove that the rubber would sit inside of it. Why can't you apply the glue to the inside of the grove and the inside side of the rubber and push it in, holding it with masking tape until the glue is fully cured. The best thing you can do, if possible, is go to a local car swapmeet. There are usually a dealer that sells a variety of rubber door seals. Make a drawing of the grove in the door, take it along and match it up.
there isn't a flat area to apply glue onto. the door has a groove running the full length around. where do I apply the glue?
Planecrazy
01-31-2013 03:34 PM
genscripter
16
11-14-2012 01:36 AM
Narwhal
06-09-2004 06:12 PM
