B5,b20,b99???
B5,b20,b99???
I have a fuel supplier locally-(not a regular gas station, or truck stop) that has BioDiesel.
I first heard they had all grades from B5,B20, and B99 and when I went in to get a tank (Iwas going to start with B5 for a couple of tanks, then go to the B20, then the B99)I was told they only had provisions to put B20 into my tank-(I understand there is a modification that I can do so that a BIG RIG size nozzle will fit into my filler neck)So my question is does anyone know IF the B99 is going to cost more than the B20 that I paid $3.08 a gallon for yesterday?? I have heard that there is enough BIODIESEL already manufactured to fuel all the diesel powered vehicles that want it and then some.....I also understand that we are now EXPORTING OUR BIODIESEL!!!!!! WHY THE HECK ARE WE SENDING OUR FARM GROWN FUEL OVERSEAS??????
I think we should be extended the BIODIESEL for the same price as DINO Diesel-I hope our farmersaren't getting greedy, I like to support them but not if they are going to send it overseas!!!!!!!!!
I'm all for anything that helps American farmers....and if exporting bio does that then I think it's friggin great idea.
I doubt if B99 will be any cheaper than B20. Lord knows it should be, but it's unlikely that it will.
What truck do you have? The big nozzle fits in my filler without any modifications.
Originally Posted by Supercab
I've got a LATE '99 F350 CC Dually 2Wheel drive, I understand that I can cut out the restrictor so I can use the big rig nozzle, I have heard that some trucks have this restrictor and some don't.
I just found this info from the National biodiesel board. read under "concerns of using greater than B20".http://www.biodiesel.org/pdf_files/B...0_20_Final.pdf
If your past the 100K (for warranty issues) then B20 or less will be fine. The colder the weather the less bio I would use. I have not had a problem with the B20 until it got down to zero degrees then it didn't have the HP. Moved to the B5 and didn't notice any HP difference (between the dino and b5) and I just know I am getting better lubrication and helping the price of the soybeans I grow.
Wheatina
Bio-diesel, Propane & Alternative Diesel Engine Fuels
09-06-2007 12:49 PM
Hamberger
61
02-07-2007 07:02 PM
PowerstrokeJunkie
30
08-19-2006 10:57 AM
digracer
12-21-2005 08:10 PM
bigredtruckmi
33
05-26-2005 09:06 PM
