sd hpop
Originally Posted by lazerf250
My truck just got stage 1s put in and i can trip my check light when i beat on her. i was wondering if i put in a sd hpop would it stop that light from coming on and would i see more power...if so how much?
different dynos, different day, but the sheets said it was there...
also stopped setting the cel at WOT with the SD pump, so I considered it fixed...
fuelman, look at this picture and it shows how you an tell if its a late model one or not.
http://home-and-garden.webshots.com/...46186803iUfcHh
on
Originally Posted by fuelman
I had opprotunity to buy used hpop this weekend but didn't because I couldn't get the bearing plate out to verify it was a17*.any suggestions.It was off a 99 with AB inj.
Before I installed the 17* when I set the CEL with the injectors I am using I could feel the engine flatline. It just stopped making power. But after the install the mid range and high end pulled quite a bit stronger. It was well wortht he effort since my pump was free and the fuel pump needed to be changed anyway so i was half way there anyway.
-cutts-
you cant determine if a pump is 15 or 17 by the humped back cover...
the way I understood it, they are all reman, and whoever does it just grabs a cover and throws it on, flat, humped, whatever...
from what I researched, your guaranteed a 17 pump with this part number
as they are all reman under this PN and a 17...F81Z9A543CRM
also, I was told that some pumps under earlier PN's could be 17, and thats when you have to take the cover off and check....somebody mentioned once you could remove the clip on the cover and shoot some air into one
of the connections and that got the plate off to check the bearing etc...
hope I didnt confuse things...maybe someone can verify what I was told.
on
RTX is right on. The humped cover doesn't mean anything unless you know for a fact its the factory pump off a late 99 to 03. Pulling the rear cover is the only way to know for sure. I have had good luck with duct tape pulling the cover and air pressure also works. One a junker that I bought to play with for DIY big oil I has to weld a nut to the cover and thread a bolt in there it pry it. nothing else would get it off but that pump sat in the rain a few times too.
