Concentric slave quick release tool
no you dont have to go to the dealer. If your replacing slave it will come with one. When i did mine i left it at home and have had to use either a flat head screw driver, or a fuel line quick release. Which ever one you can get to work better for you. you can probubly get the tool from an auto store for a few bucks.
Good luck
Good luck
You could use a small screwdriver, but I have messed up several as a result. They don't always release like they are suppose to. I bought the tool off of the Mac dealer. You can probably go to your local parts store and get one. It is a flat piece of steel with a slot in one end that fits over the quick connect sleave and allows you to push the sleave in and release it.
thedoctor
09-04-2009 09:36 PM
jbrown9709
09-18-2008 05:44 PM
greek4x4
New Member Introductions
11-23-2007 10:17 PM
1989F250
08-16-2004 05:10 AM
